John Deere 112 Mower
Keith Duddy
05-11-2008 01:13:27
I have an older model John Deere 112 lawn tractor that I am putting back together. I am trying to put the mower deck back on it, but can't seem to figure out how the belt drives the mower from the engine/PTO. The engine/PTO has a horizontal shaft and the mower deck seems to be set up to run off of a vertical shaft pulley. Anyone have any pictures of the mower deck installed on the tractor with the proper belt routings? This tractor is a 70's model year, I think. Any help or ideas would be greatly appreciated.
Dave Sherburne NY
05-12-2008 17:09:05
 Re: John Deere 112 Mower in reply to Keith Duddy, 05-11-2008 01:13:27
There's quite a few pictures on this link, maybe you
can find what you need
RayP(MI)
05-11-2008 11:39:23
Think you"re missing the front mounting, which hangs on front of tractor, under engine - between front wheels. Has two pulleys which direct betl from motor to mower deck. One of the pulleys has a tightener assy to set belt tension.
Also has the mounting arms that support front of mower.
rubberwrench
05-11-2008 02:48:59
The belt starts at the motor and goes down. The belt on the flat pulley goes to the deck and around. The lift arm comes off for the belt to incircle it.now back to the motor
