Used Auger Information Needed
jarnkm
05-10-2008 19:09:36
Recently picked up an old but good auger. The only info I can find on it is part of a sticker that reads: "Southeast Manufacturing Co., Inc.". The address, etc. is worn off. The only search info I found was an Inviro-Sheet showing: Southeast Manufacturing Co., Inc.,1715 N 8TH NEODESHA, KS 66757 and was listed as "Farm Equipment Manufacturer". It stopped here, apparently now non-existant. The gear box, etc. is in great shape but, the 2 augers have seen better days. I could possibly get by with blades and points. So far, I haven't found any like these. Any ideas or suggestions? Please??
Thanks ..... .....
DiyDave
05-12-2008 16:54:19
 Re: Used Auger Information Needed in reply to jarnkm, 05-10-2008 19:09:36
Post hole digger shafts are numerous and varied, when it comes to augur shafts. Measure the output shaft, and post it here, somebody here will tell you what matches up!
BCnT
05-10-2008 20:53:07
if youre talking about a post hole digger it mite be easier to just go ahead and replace the auger since the old ones are shot...the output shaft on most gearboxes are the same diameter.
JMS/.MN
05-10-2008 20:33:30
Are you talking about a post hole digger auger, or grain auger, etc.? Blades and points- sounds like a PHD.
jarnkm
05-11-2008 08:43:20
 Re: Used Auger Information Needed in reply to JMS/.MN, 05-10-2008 20:33:30
It is a Post Hole Digger. Sorry I wasn't more definitive.
