HELP - Where buy 6.70-15 gription tires for Corn Planter?
Faber McMullen
05-09-2008 08:57:38
Hey Guys:
I have tried for 2 weeks to find 6.70-15 tubeless tires for my corn planter (John Deere 70's model ?). No one here in Texas can find me the "grip" tires that were used. The implement is driven by the tires.
Help
Faber
Texas
maxwell99
05-11-2008 21:21:45
 Re: HELP - Where buy 6.70-15 gription tires for Corn Plan... in reply to Faber McMullen, 05-09-2008 08:57:38
Link
Faber McMullen
05-12-2008 18:10:34
 Re: HELP - Where buy 6.70-15 gription tires for Corn Plan... in reply to maxwell99, 05-11-2008 21:21:45
This is the 2nd time that I have requested that you send my your farm dealer's name. Please send me the contact info for the folks with the 6 ply tires.
Thanks
F McMullen
hd6gtom
05-10-2008 12:26:05
I just checked with my old tire supplier. They have them in stock 6ply tube type. Any local FARM tire supplier should be able to get them for you.
Faber McMullen
05-10-2008 15:12:56
 Re: HELP - Where buy 6.70-15 gription tires for Corn Plan... in reply to hd6gtom, 05-10-2008 12:26:05
Please send me their name. Not ONE farm supply place in Texas can supply them.
Thanks
Faber
Bill-NNY
05-10-2008 19:02:08
 Re: HELP - Where buy 6.70-15 gription tires for Corn Plan... in reply to Faber McMullen, 05-10-2008 15:12:56
Titan/Goodyear show a tube type. they are I-3 traction implement.
Link
Miller tire lists the Goodyear tire.
Link
HTH
Bill
Don-wi
05-09-2008 23:07:17
I've seen plenty of them with plain implement tires on them. Our 495A has some very worn and very old light truck tires on it. Not much grip left on them, but it's enough to run the planter.
Donovan from Wisconsin
maxwell99
05-09-2008 19:41:13
Link
What you want is a R-1 tire (has tractor grips)
got close, these fit my big case garden tractor.
700-16.
Might check with the company as this was the closest thing I found to your size.
John Deere may have had the tires on your planter special made for this planter.
Good luck,
Faber McMullen
05-10-2008 15:15:00
 Re: HELP - Where buy 6.70-15 gription tires for Corn Plan... in reply to maxwell99, 05-09-2008 19:41:13
Are you saying it's okay to use the 700-16 tire?
Faber
Texas
msb
05-09-2008 18:15:05
Link
John730D
05-09-2008 17:48:41
Millertire.com
maxwell99
05-09-2008 14:02:19
Faber,
you are right those tires are hard to come by.
I bet you could use some old heavy mud grib truck tires in or near that size.
may be your only option.
my neighbors drill is operated by the wheels (6 row) and it has smooth impliment tires that drive the systems and it works well.
Good luck,
Tim Daugherty
05-09-2008 11:06:51
You might try Nebraska Tire. If they don't have it I know that Gemplers does but they are expensive. I really don't know if you would need that type of tread as the planting units should turn easy enough that a smoother tread tire would work. www.gemplers.com, 800-382-8473
