Sprayer Pumps
Hugh Mackay
05-09-2008 03:39:33
I use a spraying systen to apply fertilizer solutions. My old diaphragm pump is just about shot, doesn't have the volume I require. I bought it used, quite a small pump rated around 3 gpm, thus it probably never had the volume I wanted. It currently puts out 1.25 gpm. I can't seem to get an answer locally, so the expertise of YT should have an answer.
Which of centrifical, diaphragm or piston pumps are better for this application. Bear in mind I do have other uses for this unit, where pressures I can only get from a piston pump are required. My main concern, will piston pumps stand up to use in fertilizer solutions.
johns48jdb
05-11-2008 05:14:27
 Re: Sprayer Pumps in reply to Hugh Mackay, 05-09-2008 03:39:33
after your through with any pump flush it with water and blow dry with iar, then fill it with antifreeze. turn the pump by hand so that it is trying to blow the antifreeze out the outlet end and set some where to keep it level and want get knocked over. every once in a while i go by and twist mine just a little back and forth. next spring its ready to go.
Hugh Mackay
05-11-2008 05:48:15
 Re: Sprayer Pumps in reply to johns48jdb, 05-11-2008 05:14:27
Johns: I didn't ask how to take care of a pump, been doing that for 45 years, never had a pump freeze or wear out prematurely. Back in the 1970s I was doing couple thousand acres of custom spraying each year, just never had experience with fertilizer solutions.
I just wanted to know which of centrifical, diaphragm or piston pump stood up best with fertilizer solutions. I particularly wanted to know about the piston pump as I have a good piston pump and an unrelated use whereby I require pressures in excess of 120 lbs. You know and I know I can only get those pressures from a piston pump. Now if I'm going to jeopardize my piston pump by using fertilizer solutions, then I'll go and buy a cheap pump for the fertilizer solutions.
Don't take this as a personal attack, no one has answered the particular question I asked.
SuperA-Tx
05-09-2008 20:33:23
Hugh,
See if Gemplers has something that might interest you (link below). If your spraying insecticides your wanting a presure sprayer. If your wanting it more for just applying the fertilize then I think you would want more of a transfer pump. Whatever you decide just make sure the pump if chemical resistant. Might also want to have it agitating while you apply the chemical because lots of fertilizers will settle quite a bit in a short time.
Link
maxwell99
05-09-2008 11:19:07
I use a gear pump for spraying my fruit trees, also used it when we sprayed tobacco, etc:
I works good, has brass gears, do not know how it would stand up to Fertilizer.
not a lot of volume but it will get 60-70 psi.
IaGary
05-09-2008 03:51:01
Hugh I have use Ace pumps to pump fertilizer solutions with a fair amount of success.
They are cast iron housing with a plastic impeller.
I tried to flush with water then fill with diesel fuel during storage. Without cleaning,before storage, about 2 or 3 years is all you can get out of them before rebuilding them. They are rebuildable.
They will develop about 90 pounds of pressure when needed.
Gary
Hugh Mackay
05-09-2008 04:57:48
 Re: Sprayer Pumps in reply to IaGary, 05-09-2008 03:51:01
Gary: Thank you for that information. I should have gone a bit further. This is nothing more than my parsonal vegetable garden. I was at an auction last week, picked up a new grease gun for a dollar, a Hardi back pack sprayer for $7.50 and a 100 gal. 3 point hitch 13 nozzle sprayer for $10.
I wanted a 100 gallon water tank for my trailer, just to have parked in garden when transplanting. What I got with that sprayer was new in box set of no drip nozzles, new liqiud filled pressure gauge and a Hypro piston pump that still turns out 10 gpm as it did when new probably 40 years ago. I really don't want to give my bargain to fertilizer solutions if it wont stand up to that application. I could buy another cheap volume pump for fertilizer solutions. These solutions are new to me, we didn't have them on the east coast when I farmed.
KRUSS1
05-09-2008 11:47:45
 Re: Sprayer Pumps in reply to Hugh Mackay, 05-09-2008 04:57:48
A centrifugal pump is what I have found to be the best choice for pumping fertilizer. Liquid fertilizer has a tendency to be "not quite" all liquid, and of course it's corrosive and has a gigh affinity for any dirt present, so is abrasive.
