NH 1411 Horsepower
Greg Sinder
05-07-2008 17:37:01
I have a 65hp (55hp PTO) tractor that I have used to pull a haybine. I am thinking about upgrading to a NH 1411- I know the recommended horsepower is 80, but could I get away with pulling it with my tractor?
Don-wi
05-08-2008 18:52:57
 Re: NH 1411 Horsepower in reply to Greg Sinder, 05-07-2008 17:37:01
I'm not familiar with NH equipment so I'm not sure how wide a 1411 is, but we use a 85 HP tractor to pull a 14' Hesston 1014+2 Hydra-swing. I wouldn't want to go any smaller than that on that machine.
We do use our 105 HP Oliver 1855 on it as well when I want to get my head out form under the sun and that runs it great.
Donovan from Wisconsin
Josh in WNY
05-08-2008 05:12:59
I tried out a used 1412 (the impeller version of the 1411) last year to replace our old NH 488 haybine. I put it on our Ford 5000 (about 65 to 70 horse) and it would run it, but it worked it like crazy. I couldn't mow any faster than I did with the 488 and what little I used it (not even 2 acres) almost overheated the engine.
I would say 80 hp would be the bare minimum to run a 1411. More hp might be needed if you are working in field with a lot of hills.
We ended up getting a used CaseIH 3309 (same thing as a New Idea 5209) and the Ford 5000 runs it nice. It works it a little harder, but that is partly because I picked up two gears (running about 3 mph faster than I did with the 488). I think the 3309 is a good mower, but make sure whatever discbine you might buy is not completely worn out. They get pretty expensive to fix if the cutterbar is shot.
Josh in WNY
kurt
05-07-2008 19:10:22
A friend puts up about 60,000 bales a year and has 2 discbines. He says 10 HP per foot of cut. So a 10' cut discbine would take a 100 to mow through anything in its way.
backwoodsfarm
05-07-2008 18:07:07
I know you'll get lot's of feedback on this one so here's my two cents. I tried out a JD 1350 disc mower conditioner last year with my 65HP John Deere. The mower is 8'2" and and it was OK in short second cut hay. I think in thick hay it would have been a little to much for that tractor. The 1411 discbine is a 10'4" machine and it would probably break something in a 55HP tractor. Until you mow a lot of hay with a disc mower conditioner, it's hard to believe just how much power they require. If the book say's 80, I'd run it with 80 or more.
Ozarker
05-07-2008 19:01:35
 Re: NH 1411 Horsepower in reply to backwoodsfarm, 05-07-2008 18:07:07
Dad has a JD 2550 pulling a NH 408 which is an 8 foot version of a NH 411 discbine. There are times when the NH 408 will bring that tractor to it's knees.
I'm running a NH 1412, the impeller version of the 1411 with a Deere 4040 (90 hp). Most of the time it handles it fine. There are a few fields though where it makes that 4040 snort. NH makes a tough machine, but they do like power.
Bob
JoshuaGA
05-07-2008 17:58:44
To be honest, I think you have a snowball's chance in hell to pull that thing, especially in heavy hay. I think you might be better off with a disc mower tedder combo. Going to be much easier on your tractor. Otherwise, you need the 80 horse to pull it. 100 preferably. Just My Thoughts.
JoshuaGA
RodInNS
05-07-2008 18:00:43
Not a hope in blazes. Get a tractor or get a haybine, but you won't run that discbine with what you have.
You might get it up to speed while sitting in the yard, but it takes a lot more power to run a crop through it, and that much more again to make any speed. NH is awful optimistic with their 80 hp recomendation. That's a 10'4" mower. That's 100 PTO hp material here.
Rod
ihr190
05-07-2008 17:45:49
Pardon my ignorance, but is a 1411 a discbine?? If it is, I think you are going to need a little more steam. If not, I know the factory often tells you a horsepower level that seems high. They do this because the newer tractors are not built as heavy as the older ones. An example would be a Case 770, is only 55-60 hp, but is a very heavy tractor for its size. I have seen several people pull a hydroswing with an M Farmall. Worked just fine, really. After having said all that, if it is not a discbine,I think you will be just fine. This is my opinion ofcourse.
HAYBOY1
05-07-2008 19:41:37
 Re: NH 1411 Horsepower in reply to ihr190, 05-07-2008 17:45:49
Ever think about a New Idea (red version) 5209? Don't know from experience but have heard they use a lot less power to run them. 1411, absolutely no way would I pull it with that tractor, 411 would give you a workout
