massey harris #6 sickle mower questions
jocco
05-06-2008 18:49:47
I might have found one to complement my 44 this is the semi mounted 2 wheel type. Any opinions or knowledgeable people? All in all i am pretty familure with sickle mowers just not this one!
charles p
05-16-2008 09:49:46
 Re: massey harris #6 sickle mower questions in reply to jocco, 05-06-2008 18:49:47
i own 2 of those mowers. one working, one parts. working one works great. just make sure all rock guard are same so cutter bar slides easy otherwise you might break pitman arm. stripped mine down to last nut & bolt and rebuilt. one had a broke slip clutch but only cause somone set too tight. just need to set spring about one turn in if rebuilt right. got all cutting parts from www.balsters.net including knife head. talk to Les. he knows sickle mowers!
Leroy
05-07-2008 05:56:21
Just make sure you get all the mounting brackets with it and hope that they are the correct brackets for your tractor, there were many different brackets made to work with many different model tractors.
