Caroni rotary tiller
Robert Bourman
05-06-2008 16:49:57
I broke the drive chain on my 60" caroni tiller. A #80 master link doesn't quite seem long enough as far as the pins go in relation to the roller. Can I just put a hole new #80 chain on it or do I need to buy the expensive chain that the factory recommends? Anyone have any experience with this?
Thanks,
Robert
Ebfarmer
05-08-2008 10:26:09
 Re: Caroni rotary tiller in reply to Robert Bourman, 05-06-2008 16:49:57
That should be a 16B British Standard roller chain. Links are available but you will probably have to go through an industrial maintainance supply to get them. Here is a link to HKK's catalog page. OK, I'm too new to post a link, but if you do a google search for 16B roller chain something should show up.
Murn ga
05-07-2008 08:45:55
If the pins are to short,try an 80 heavy duty conn link.
Gerald J.
05-07-2008 08:45:15
Its probably a metric chain. The dealer may be the only handy source.
Gerald J.
Tx Jim
05-07-2008 03:13:43
 Re: Caroni rotary tiller in reply to CT_Farmall, 05-06-2008 16:49:57
Robert
Different size(pitch) roller chains require different sprockets that the teeth are spaced different. I recommend getting correct coupler link or correct new chain.
Robert Bourman
05-07-2008 04:26:21
 Re: Caroni rotary tiller in reply to Tx Jim, 05-07-2008 03:13:43
Any idea what size the chain actually is? The tiller is made in Italy and there is no marking on the chain in regards to size.
El Toro
05-06-2008 18:01:50
I would try the repair link first. Hal
Robert Bourman
05-06-2008 18:49:21
 Re: Caroni rotary tiller in reply to El Toro, 05-06-2008 18:01:50
what do you mean by repair link? One from Caroni or a regular 80 chain?
El Toro
05-07-2008 15:38:39
 Re: Caroni rotary tiller in reply to Robert Bourman, 05-06-2008 18:49:21
Master link. Hal
