How do I replace discs?
BBurton
05-05-2008 06:45:53
I have a disc with several discs that need replacing. The ones on the end are easy as I just have to remove a nut and the disc slides right off but how do I access the inner discs? There is only one large nut on the outside of each gang. Do I need to pound the shaft through from the outside after removing the outside nut? The discs are 15 inches across with a one inch square hole in the center.
third party image
thurlow
05-05-2008 09:23:36
 Re: How do I replace discs? in reply to BBurton, 05-05-2008 06:45:53
Drop the gang(s) and roll 'em out from under the disc; remember the order in which you remove "BLADES", bearings, spacers, etc. Remove nut before dropping gang and re-tighten after replacing back under disc.
MoMike
05-05-2008 06:50:09
You should have carrier bearings on each section. When you remove the end bolt, drop the carriers and the whole thihg will seperate, discs and spools.
