Cylinder for Fred Cain Scissor lift
MWRR
05-04-2008 19:27:10
I just purchased a used 3pt Fred Cain scissor lift bale spear. Can anyone tell what size cylinder I need to use on it.
MWRR
MWRR
05-05-2008 18:41:48
 Re: Cylinder for Fred Cain Scissor lift in reply to MWRR, 05-04-2008 19:27:10
Thanks for the response.
MWRR
Hay DR
05-04-2008 20:01:03
3x8 SAE tie-rod cylinder is what we use. You can also use a hydraulic toplink cylinder as well.
paul
05-04-2008 20:17:27
 Re: Cylinder for Fred Cain Scissor lift in reply to Hay DR, 05-04-2008 20:01:03
I agree with the cyl size. This is the typical farm hyd cylinder. the 8 part is the important one, a little thinner or fatter shouldn't matter as long as the tractor can move it.
Had to reread your message a few times, you mean a hyd top link would work in that spot? You can't use a hyd toplink cyl _with_ the sissors lift, as it connects directly to the tractor - it doesn't use a top link at all.
--->Paul
Hay DR
05-05-2008 04:30:21
 Re: Cylinder for Fred Cain Scissor lift in reply to paul, 05-04-2008 20:17:27
third party image
A Fred Cain scissor lift can be used with a fixed toplink, hydraulic toplink and/or a hydraulic cylinder with clevis ends and 1" pins. In the picture you can see the piece that mounts on the lower lift arms can be turned around for use with a toplink.
paul
05-05-2008 09:50:34
 Re: Cylinder for Fred Cain Scissor lift in reply to Hay DR, 05-05-2008 04:30:21
Thanks - I bought one from you.
They won't work with a hyd top link afixxed to the tractor tho, is what I was getting at.
The toplink (fixed or hyd) would be used in place of the hyd cylinder, not as one normally does on the tractor itself as the actual top link.
Pretty simple machine, with a lot of different agngle designs to it. Wish they had made the bottom 2 pegs screw-in, could put small forks on it & have a forklift - suppose that opens up a whole can of worms as to people overloading it.
--->Paul
