ranch hand round baler
chris maga
05-02-2008 06:24:43
Found a older belt ranch hand round baler (it's also marked vermeer) at a local dealer. Has hyd bale tension. Uses two hydraulic hoses with a rope you pull which switches a hyd box back/forth to send fluid either to the rear gates to to the hydraulic tie. Can't remember the exact model humber, think it has HD after it. Think its a 4' wide baler. Couldn't find a corresponding vermeer number to get specs.
Anyone know anything about them and when they were made?
Hay DR
05-02-2008 07:06:38
 Re: ranch hand round baler in reply to chris maga, 05-02-2008 06:24:43
They are called Farmhand, usually red in color, and their design is very similar to a Vermeer F & H series balers. They do have different bearings and shaft sizes due to being manufactured outside the USA. You can have some parts problems matching them to a Vermeer equivalent. Many of the Vermeer parts are exactly the same but 15% are not the same. The Farmhand balers do work and are usually worth $1,000 less than the Vermeer equivalent.
SgS
05-13-2008 17:55:14
 Re: ranch hand round baler in reply to Hay DR, 05-02-2008 07:06:38
Bought my first round baler today. A Vermeer/Farmhand 504F. So is it a Farmhand or Vermeer brand? It was yellow at one time. I need a manual, can anyone give advice. Dealer also told me I can bale a 3ft-5ft roll. Is this true? I dont know anything about balers, obvious huh? It ran well in the lot.
