hey formly PAMike
mgm
05-02-2008 05:47:31
So it is my understanding that with auto (which I have) I do not need the alarm or the bale command system correct? Therefore how do I contrroal the tie and the ejectoin form the baler? Is this control manuelly by the tension of ? and is the baler ejection from the hydralic system
r john johnson
05-02-2008 07:09:19
 Re: hey formly PAMike in reply to mgm, 05-02-2008 05:47:31
If you have determined that you have the Autowrap then that simplifies matters. The system works as follows. When the bale reaches a preset size, which is adjustable, a mechanism trips a clutch that starts the worm gear box for the twine tie. The twine arms drop down to the center of the bale for several wraps, moves outward, pauses for several wraps then move to the fully retracted position which triggers the knives to cut the twine. All this happens without the operator doing ANYTHING. The buzzer on this system buzzes when the tie arms start and again when the arms finish the tie cycle. The first buzz tells you to stop the tractor and the second buzz tells you the bale is tied and is ready to eject. IF you want to look back and watch the indicator arm for the tie cycle, then you do not need the buzzer. The buzzer is only telling you what the baler is doing. I bale with a cabbed tractor and cannot hear the mechanism start to tie, and I put up enough hay I do not want to have to watch every bale to see when it is tying, so I rely on my buzzer. To ME this is much easier, though your results may vary.
To eject the bale, you must wait until the bale is tied, open the tailgate with the tractor hydraulics and once the bale rolls clear on the ramp, close the tailgate with the hydraulics. There is an indicator to show that the gate has latched. This is explained in the manual.
FWIW
The Bale Command is a small computer inside a box, with an LCD display and a bunch of buttons. Sensors on the baler send inputs to this "brain" which sends signals back to operate the twine tie. I am not familiar with this system, but as I understand, you MUST have the monitor to make the twine function.
HTH
John
mgm
05-02-2008 07:14:20
 Re: hey formly PAMike in reply to r john johnson, 05-02-2008 07:09:19
so it sounds to me, buying the alarm system is worth the money ?maybe it depends on the cost? Thank you I was worried because i did not recieve any electrical boxes with the unit thinking at the time that it could not operate without them
