Width of an Oliver Superior #26
Matt in the Thu
05-01-2008 10:03:09
I need to know the overall width outside of rim to outside of rim for an Oliver Superior #26, to know if it will fit sideways on my 10 ft. long trailer. Thanks.
Leroy
05-04-2008 10:50:28
 Re: Width of an Oliver Superior #26 in reply to Matt in the Thumb, 05-01-2008 10:03:09
I do not know about Oliver drills but my IHC books say they made the MF drill in sizes of 9 x 7", 10 x 7", 11 x 7", 12 x 7", 13, x 7", 16 x 7", 8 x 8", 10 x 8", 12 x 8", 16 x 8" and while it does not give total width the drilling width of a 10 x 7 is 5' 10" to 9" 8" for a 16 x 8 with 15" to outside of tire to opener center on each side. mine is a 13 x 7 so 13 x 7 = 91", book says 7'7" and ad 2 feet on each side would make it 9"7" with skinnerier tires than I have so it would have to be a verry small size to fit on a 10' trailer
Matt in the Thumb
05-05-2008 10:30:29
 Re: Width of an Oliver Superior #26 in reply to Leroy, 05-04-2008 10:50:28
It fit! I counted, but can't remember now if it was an 11 or 13 hole. It was about 9 feet to the outside of each wheel, steel wheels by the way. Those things are heavier than they look!
Leroy
05-04-2008 10:58:05
Anything smaller than an 11 X 7" would have been narrower than that tractor and that tractor had enough power to pull the biggest IHC model M drill at 24 x 7" = 168" or 14'. These drills were made at the same time as the Oliver.
Matt in the Thumb
05-02-2008 10:23:04
Sorry don't have all the details. From my recollection, it seems to be about 10 feet wide, give or take a bit. It was used with an Allis WC, so I don't think it's that huge. I just need to know if I can load it sideways on my 10 foot long trailer.
Leroy
05-02-2008 06:28:19
If you give the number of openers and the spacing of the openers then you might get an answer. If it is a 10-7 drill it will be a lot different in width than if it is a 17-7 drill that would be 3 1/2' difference.
