Oliver plow
TGIN
04-29-2008 02:55:51
My neighbor bought a 565 oliver plow 3x16 semi mount at a auction last fall and it needs shares,molbords,etc . He got no help in town , it was`nt in the computer . Value-B dont list the 565 . Can someone send us in the right direction or will parts from another model cross over .
Randy-IA
05-01-2008 19:19:55
 Re: Oliver plow in reply to TGIN, 04-29-2008 02:55:51
Hi , If it has 919 frogs you will have a tough time getting parts . Those are for speedex bottoms as far as I know . I have those on my 565 . I can get everything through Agco . They are pricey but they fit right . I tried weise parts and they don't fit with 919's . 619 frogs are different ( fit raydex maybe ? ) and after market parts seem much more available for them . 619's are much more common I guess . Good luck ! ...Randy
TGIN
04-30-2008 01:56:27
 Re: Oliver plow in reply to larryh, 04-29-2008 15:55:04
Thanks guys for the help . Larry I`ll call ya if it dont workout in town .
Don-Wi
04-29-2008 15:33:57
You can try Shoup also. If you've got a Fleet Farm in the area they should have what you need, if not they can get it.
Our 565 uses the same wear parts as our 546, and should be the same as what White plows use.
And as you found, Oliver did make some plows (atleast some parts) for Ford plows.
Donovan from Wisconsin
TGIN
04-29-2008 13:20:48
He stopeped by with his parts today and they are all the same as my Ford plows . So to the Ford dealer he`s going , they sell the aftermarket .
Anthony
04-29-2008 08:49:23
Did you check here? You should have no trouble finding more reasonable aftermarket parts, but iron has been going up $$$.
Good luck.
paul
04-29-2008 08:06:02
Link
Should be able to match them up? Forget the plow number, get a tape measure & see what fits.
--->Paul
HAYBOY1
04-29-2008 05:46:37
There is a guy in Nassau, Ny If you can't get an answer from him there isn't one. You would have to call information for his number, but his name is Syd Chavin. I believe he is on Schoolhouse Rd in Nassau, NY. Good Luck to ya
rubberwrench
04-29-2008 03:09:19
Check with your white dealer
TGIN
04-29-2008 06:15:24
 Re: Oliver plow in reply to rubberwrench, 04-29-2008 03:09:19
Local Agco Dealer wants over $50 for shares and over $200 for moldboards ! Have prices went up that much . Got some aftermarket fords for $17 a few months ago !
Anthony
04-29-2008 08:20:53
 Re: Oliver plow in reply to TGIN, 04-29-2008 06:15:24
Can you read the numbers off the shares and moldboards? You should be able to find Wiese or Crescent parts for replacement.
CRESCENT: http://www.peak.org/~crescentforge/products/products.htm
Link
