I'll start. I always like to see replys to my messages...so here goes... Based on the limited descriptions you provided, i'll do the best i can given my limited experience.Oliver 10'disk. If drag type $100, less $10 for each broken or nicked disk and less $10 for each bad bearing. IH 10'harrow. If this is a spike type on metal frame then it's probably two sections, right? if so then they go for about $50/section. thats $100, less $10 for each bent or missing part. If this is spike type with wood frame then $40. 12'cultipacker. $10/ft. more if perfect shape, less $20 for each broken, missing piece or bad bearing. (this is for metal packer w/metal frame (can have wood bearings)) $10 if an old round log pulled by couple of chains on each end. 3pt post hole digger. Again, this will vary LOTS. If a modern factory made digger with no bent pieces and proper gearbox condition and all other things are right then $300 w/clutch drive or $200 w/shearpin drive. If homemade digger or bent/missing parts... then $25 - $100. 1 btm AC plow. If this an antique, then it's whatever the market will pay that day - (who is there at auction - who wants it bad). Otherwise, if a normal cat1 3pth then $100 (less $50 for bad mouldboard, less $20 each for bad shin or share). If an AC prepritary type hitch (rather than a normal 3 pt hitch) then $75 (same deductions apply as above )
