Has anybody seen a cultipacker like this one?
bobby grant
04-27-2008 08:36:27
third party image
third party image
I recently acquired this 3-pt. hitch cultipacker. Is anyone familiar with this style? It has a missing wheel on one end. Can anyone tell me anything about this cultipacker or where I could find a wheel for it?
bobby grant
05-03-2008 11:30:00
 Re: Has anybody seen a cultipacker like this one? in reply to bobby grant, 04-27-2008 08:36:27
The name plate is faded real bad, but you are correct. It does say True Blue
higgins
04-28-2008 13:55:53
This looks more like a converted rotary hoe.
cskent
04-28-2008 09:34:24
I have no idea about this unit, but as far as Burch Plow Works goes, there was also a manufacturer by that name in Crestline Ohio. They built turning plows early on, then later made snow removal plows and elevators as well as other other items. I think they closed in the early 1970's Does the tag list where it was made?
maxwell99
04-27-2008 10:37:14
No, I have not seen one like it, but when I have to move mine old one from one field to another, it would be nice to have a 3 pt on it.
Great fine, good looking machine.
James22
04-27-2008 09:52:10
That looks like what the Europeans call a "roll/ring press". It is used directly behind the plow to consolidate the plowed ground and conserve moisture. I believe it also helps control slugs. I've also seen in old sales literature such a device nested between a plow and drill,for a one pass operation operation. I wouldn't be surprised if it originated in Canada, which tends to use more European practices.
bobby grant
04-27-2008 08:38:53
I forgot to mention that the nameplate reads Burch Plow Works...True Built model. It is 7.5 to 8 feet wide.
Jerry Coulter
04-27-2008 14:02:00
 Re: Has anybody seen a cultipacker like this one? in reply to bobby grant, 04-27-2008 08:38:53
Burch Plow Works was in Evansville, IN. The line was called True Blue. We had the franchise here and sold disk harrows, offset disk plows, planters and cultivators. I still have some N.O.S. corn planter sprockets lying around here. But I can't recall that cultipacker.
