Gravity box extentions sources?
Dave from MN
04-27-2008 05:52:18
Any one know of a source to order the metal hieght extentions for gravity boxes? I am buying 3 of them and they have wood extentions which are kinda shoddy. As with everything I am gonna refurbish the gears and boxes and paint the inside with that slippery(graphite?) paing, and I want to add the correct extentions to maximize capactity within the safe limits.
Greasey Hand
04-28-2008 13:33:00
 Re: Gravity box extentions sources? in reply to Dave from MN, 04-27-2008 05:52:18
I have made some in the past. but not at todays steel prices.
I can get a price of the steel & braking them, need to know the length & how high you want them.
The steel only comes 10' long so would weld them
to make the length you need.
You paint them?
akb
04-27-2008 23:26:26
Dave from Mn
I am currently checking it out also.I was thinking rough sawn oak ? Let us know what you find out.I am located by Princeton.
Dave from MN
04-28-2008 05:23:29
 Re: Gravity box extentions sources? in reply to akb, 04-27-2008 23:26:26
My step sons uncle has a machine shop in little falls. I am gonna talk to him as well.
JMS/.MN
04-27-2008 15:29:46
Is that metal shop still operating just NE of Mimbach"s? Also check with Minnesota Structural Steel, Lincoln Av, near Midway Iron. They retail and manufacture.
JoshuaGA
04-27-2008 08:27:59
Nearest metal shop will make them.
JoshuaGA
James22
04-27-2008 10:25:23
 Re: Gravity box extentions sources? in reply to JoshuaGA, 04-27-2008 08:27:59
Good advice. Had a local fabrication shop make galvanized 16 inch extensions for one wagon. Just need to find a shop that has a large enough sheet metal brake to form the entire side in one piece, if you want to avoid a splice.
Maark
04-27-2008 07:46:24
Don't know about the metal ones unless you contact the original manufactuer. 2x12 boards make nice extentions though.
