JD #52 plow problem
ster745
04-26-2008 08:16:51
Plow will drop but won't pick itself back in the raised position. Is there a place I can get a new ratchet. It is a open clutch type. Thanks
Mark-IA
04-27-2008 07:44:23
 Re: JD #52 plow problem in reply to ster745, 04-26-2008 08:16:51
Have you taken the wheel off the hub? Make sure there isn't any caked grease or dirt on the inside of the clutch drum. Also make sure the roller assembly inside isn't rusted so it doesn't turn.
Earl -IL
04-26-2008 08:28:43
Check for broken spring & clean out the grease & dirt. Earl
ster745
04-27-2008 06:58:14
 Re: JD #52 plow problem in reply to Earl -IL, 04-26-2008 08:28:43
Spring is not broken & not filled with grease and dirt. Would it be the spring is just weak.
Thanks
