MF 725/925 or Badger BN1000/1005 owners pls help
jimgoddard
04-25-2008 08:07:12
I need some help w/ a part. It seems the spring to tension the reel belt is obsolete and has been for some considerable time. Neither Miller or Artsway know what its supposed to look like (no blueprint and dont know length. dia, wire size) or what the deflection of a properly tensioned belt should be. The spring Im referring to is connected to a tube/eye bolt assembly on the left rear (looking at it from the front). If you have the original part Id appreciate it if you could give me the length, dia and wire size. Even if you dont Id be interested to know how much tension is on the belt (deflection at some point)?
NE IA
04-27-2008 14:55:02
 Re: MF 725/925 or Badger BN1000/1005 owners pls help in reply to jimgoddard, 04-25-2008 08:07:12
I would be very suprised if anyone will respond as most of us would assume you could be talking about part of the space schuttle. If you give them a little more detail I would guess someone could help you out. I know nothing on MF or Badger, but you did mention Artsway. Most posts that are not detailed are usualy left unanswered.
