Air Seeder Tank Fan Tach
Chris in SK
04-21-2008 20:10:15
I'm looking at a Flexi-coil air seeder tank that has the monitor missing. A new monitor is over $2500, recon $1000+. The monitor has warning lights and switches that I think I can wire in. It also has a digital tach to show the hydraulic fan speed, which needs to run and be adjustable between 2000 - 4000 rpm. My question is, could I wire up an engine tach like you'd fit to a vehicle. The fan shaft has a speed sensor.
Thanks for any replies,
Chris
oj
04-23-2008 17:39:10
 Re: Air Seeder Tank Fan Tach in reply to Chris in SK, 04-21-2008 20:10:15
farmtronics in Regina sell ISSPRO gauges, and may be able to help, they helped me before with electronic monitors. oj in mb.
Bob
04-21-2008 23:15:16
Those fans use a pickup unit consisting of a permanent magnet and a wound coil, just like a diesel tach that "counts" flywheel ring gear teeth.
Look up "ISSPRO" on GOOGLE. They have a number of tachs that use pickups of the type I just described. Call them, and see if they think it will work.
