Van Brunt Drill
Worth Turley
04-19-2008 13:57:49
I just got a Model FB 13-7 grain drill given to me. it is pretty good shape with one exception.
the pickup gears for the seed are really rusty. i think i can get them apart; but after taking the seed tubes off it looks like their is a thin piece of metal inside the holder that holds the gear in place that has completely rusted out. a few of them are still in place but alomst gone.
can someone give me ideas on this. I just want to use this for food plots. Thanks.
Kelly MT
04-25-2008 22:39:57
 Re: Van Brunt Drill in reply to Worth Turley, 04-19-2008 13:57:49
I have several old Van Brunts that I use and the seed doors do rust out. I made some doors last year out of some sheet metal. I salvaged the lever by drilling out the rivet and used a small bolt to attach it to the new door. They worked good and only took a little while to make.
farmer101IL
04-22-2008 05:10:34
Your in deep doo doo if you want to run that thing this year. My drill was in the same condition as yours. DON'T TRY RUNNING THE DRILL WITHOUT MAKING SURE THE SEED SHAFT WILL TURN FREELY. You will end up breaking a tooth on the gears or teeth. Alot of work to get one rusted going again. I made my own seed gates after seeing what Jd gets for them. Most of the cast iron pieces will weld real well with a wirefeed. I had 2 gears with teeth off of them. The gentleman that had it before me tried to breakit loose by putting it in gear. It twisted the seed shaft and broke two gears. I got one off of ebay the idler gear. the other i welded a tooth back on it . It works well.
I figure pulling the whole thing apart and rebuilding took about 2 weeks to finish. On the upside i sure learned how the whole thing works!!!!! remember it you want to replace a piece times it by 13 gets kind of expensive.
Have pictures somewhere if interested of the whole project.
Farmer
Worth Turley
04-29-2008 10:17:33
 Re: Van Brunt Drill in reply to farmer101IL, 04-22-2008 05:10:34
Thanks, for the info. I would love to see any pictures, as well as how you made the doors. Mine
are to far gone to get deminsions off of. I do waterjet and laser cutting and could more than likely make the doors if i had deminsions. Thanks, again. Worth.
DiyDave
04-21-2008 10:09:52
If your seed shaft is froze up, you are in it deep. make sure you can get it to turn with a wrench. Also if you can't get the seed rate adjustment to slide back and forth it may be too much wrong with the drill to economically fix it. Make sure you are turning the wrench on the seed cup shaft. Most of the time on these drills the fertilizer shaft is fubar!
Tx Jim
04-20-2008 03:42:15
 Re: Van Brunt Drill in reply to Texasmark, 04-19-2008 13:57:49
I think JD still sells feed gates for Van Brunt drills. They are easily replaced.
DiyDave
04-19-2008 17:34:48
Is the thin piece of metal you are referring to about 2" X 2" square, more or less? If so, I think you are referring to the seed doors, they are set with a lever in the center that indexes into the sides of the same area, there will be 2 notches in one side of the area in question, and 1 on the other side. The reason for this adjustment is that different seeds are different sizes. If you want to temporarily rig this to fix a rusted out seed door, here's what I would recommend: First, be sure that the feed gears are moving, by putting a wrench on the common shaft, and making sure that the whole mechanism turns. Then see if the seed opening adjusting mechanism will slide open and closed, look at the seed gear, you will see that one side of the gear slides into a socket, if it aint doing this, you need to free up this adjustment. Once you have this sliding back and forth freely, then you can set the seed opening to the right setting for your seed. I will assume that not all of the doors are rusted out, look at the good ones, and you will see that the only opening you should have for the seed to come through is at the top right of the seed door. The solution is to use silicone caulk to goo the rusted holes shut, or use the silicone to glue new pieces of metal or plastic over the holes. Not pretty, but functional! Of course, the reason they rusted out in the first place is that someone left seed in the drill, and the malting seed produces an acid that speeds rusting, so the answer to the problem is to NEVER leave seed in the drill overnight. Vaccuum it out with a shop vac each time you are done, or each evening.
Worth Turley
04-21-2008 04:51:06
 Re: Van Brunt Drill in reply to DiyDave, 04-19-2008 17:34:48
Yes your description is correct. It looks like they have a little lever on them held be a rivit. Unfortunately all of them but two are completely gone; and those two are rusted stuck. What you are saying is that i can replace those without replacing the complete assembly,correct. The slide adjustment and everything is stuck rusted. the seed gears are also rusted pretty bad, but i think i can remove all of them and get that part back in working order. I did notice that the Shaft that turns everything is slightly
twisted. If i have to replace all the seed doors and gears
do you think it would be worth it, or should I call it quits?
