Please Identify, 7 foot disk
cj3b_jeep
04-17-2008 11:19:16
third party image
I bought this disk the other day off the local craig's list, it's about 7 feet and has pretty good sized disks. It has an adjustment for the length of top link and has a very unusual way of adjusting the angle of the discs, see my flickr page for more photos. I'm looking to find out the make of this disk.
BBurton
05-13-2008 13:49:27
 Re: Please Identify, 7 foot disk in reply to cj3b_jeep, 04-17-2008 11:19:16
All the discs pictured look like my disc although mine has Youngstown YC stamped in several places. Are the Love and Youngstown YC discs from the same company? Does anyone know where to find a manual?
Ultradog MN
04-17-2008 16:59:53
I agree it is a Love disc.
I bought one like that completely worn out for the disc blades.
It's mostly gone now but I still have the front arched pipe. Going to scrap it this summer. Was thinking about Sawzalling out the chunk of pipe with the tag on it and selling it on ebay.
The biggest problem with those older discs is they have a 7/8" square shaft and any replacement bearings are 1 1/8".
I cut the old wood bearings off a disc and replaced them with new cast iron china mades.
Was a bunch of monkeying around but I did build a disc that will last for another 50 years.
Murn Ga
04-17-2008 14:11:43
This looks similar to a disc made by Love in the fifties. Go to imp archives and search for Love or manuals on the 8n. web site.
Billy NY
04-17-2008 12:18:53
Welcome to the unknown disc club ! Yours looks identical in many ways to mine. At first glance, I thought mine was a home made rig, but I do remember that it was new on the lot of our ford tractor dealership in the early 70's, so I thought it to have been manufactured, on mine the rear tube was repaired and strengthened, I just cleaned up those old repairs and put some healthy stick welds on there, and replaced 1 disc that the hired help broke, last time that will ever happen, had this thing for years, how the heck do you break a disc out of the center ?
It has the oil soaked hard wood bearings, I'd like to replace mine, but have no idea where to find such a thing or who in the woodworking world would be able to fabricate them from the correct hardwood and cut with the grain in the correct direction. Heard those wood bearings last for years if you don't grease em.
If anyone does know who made these I'd like to know too, saw one of these in gray, on this forum in the fall of 2005, by someone in western NY, he asked the same question.
It's a good disc for a small utility tractor, I just turned over a swath through a field the power company had a silt fence installed that left a trench I wanted smoothed over, 2 bottom, then this disc, it works nice, and easy to adjust and take apart. I would imagine you got it inexpensively, always curious as to what one of these relics were worth.
third party image
cj3b_jeep
04-17-2008 13:16:19
 Re: Please Identify, 7 foot disk in reply to Billy NY, 04-17-2008 12:18:53
Boy, that looks just the same as mine! Wood bearings? I thought those went out with conestoga wagons. It has 2 grease points per axle so I greased it this morning. I paid $450 for it. Probably too high, but I needed a 7 footer. A new "king cutter" version is $1300 bucks at TSC.
Billy NY
04-17-2008 13:48:43
 Re: Please Identify, 7 foot disk in reply to cj3b_jeep, 04-17-2008 13:16:19
These do look alike, same steel in the same places, though mine has some scraps welded to it, prior to that coat of yellow, it sat from 1981, to 2002, overgrown in some kind of brush that grows here, you could not even see it ! I set it on some wood blocks, was last pulled with a 2010 JD.
I really needed a tractor back on this place, just been too long, and most of the fields are wood lots now, my excuse was, well I need a tractor to go with those discs, and it was kind of neat to have something like an implement that came from our old dealership.
It was new when it came here, probably used a few times, prior to '81, then I decided to do some food plots. It had all the orginal discs until the hired fool at the horse place broke it, I had set up 2 tractors, one to plow and one to disc but the darned help became so unreliable I never got to turn those fields, got p#ssed off after a summer of putting up with idtiots and having to do their work, no time for the fields, my father let someone on the tractor with the discs, no rocks in these fields, not sure how he broke the end one off, blew the center out of it. Always a story, just an old set of disc's, but I really like this one, it works great.
Check yours, look where the axle is attached to the frame, it passes through a pipe/tube, anbd you can see the ends of those wood bearings sticking out. Hard wood bearings, impregnated with oil are supposed to be really durable, however you have to keep the grit out of em, grease apparently will hold the grit from working in the soil, not 100% sure, I always kept em greased, all the fittings were original and they each took grease, was surprised at that from sitting too long. The King of Obsolete in the great white north of Manitoba, takes the carrier rollers off all his crawlers and uses straight hard wood blocks instead, due to the snow conditions, they seem to hold up well.
Probably some long gone manufacturer, but I'd think in good shape $450-500 is fine, maybe the newer ones are better built, but about the only thing you would have to deal with on these is those wood bearings.
They do a nice job, turned and disc'd this patch over 2x to break up an old garden in '04, real deep top soil, made a nice seed bed, used rye straw for mulch, grass germinated, then the next spring the rye came up from all the seed in the straw, had a cover crop and never new it, the grass came out strong, no weeds at all.
third party image
BCnT
04-17-2008 16:53:52
 Re: Please Identify, 7 foot disk in reply to Billy NY, 04-17-2008 13:48:43
main deal on grease is it pushes out any grit that works its way in so be sure and make it ooze out the ends till grease looks fairly clean...do that and them bearings will outlast you...same thing goes for the grey iron type.
cj3b_jeep
04-17-2008 14:05:09
I've been doing rye and clover in this one particular field for two years now. Someone, before I owned it, stripped most of the topsoil off. I've been plowing and disking leaves and other stuff into it every fall and it looks much better than when I started. I was using an old drag disk but it was really bad and too light. I can't decide what I'm going to do with it this year, but was thinking of corn, with a cover of clover.
