source for Hessston PT-10 MOCO used parts?
tiptonfood
04-16-2008 10:32:22
Need for Hesston PT-10, counter balance spring for head and Drive pulley / belt and unable to find used parts locally in Michigan, any suggestion on sources would be apperciated. Thanks Jeff
Joe(TX)
04-17-2008 05:18:49
 Re: source for Hessston PT-10 MOCO used parts? in reply to tiptonfood, 04-16-2008 10:32:22
The pulley on the gearbox or on the roller? Like was mentioned which belt drive is it? I would go to the dealer for the belt. I have a junk PT10. I will check to see what I have. Email me if interested.
Der Unimog
04-16-2008 18:59:16
Whenever I need a part for my PT-7 I get it
from the AGCO/Hesston dealer. It may not be
the cheapest but they always have filled the
order.
Unimog
KEH
04-16-2008 17:56:21
FYI there were 2 pt 10s, an old one and an older one. I had both. The older one had an 8 foot cut, did not float over uneven ground, had a round drive belt under the back that was hard to replace. Would cut any height crop. The newer one would float better and cut extremly well, better than the 469 NH I had later. It had a 9 foot cut.
All Hesston equipment I ever dealt with was very well made.
KEH
hayray
04-16-2008 16:40:53
It is a long shot to find used parts for that, but you could try calling Worthington Ag Parts in St. Johns, they have several huge salvage yards in other states as well and may be able to locate the parts for you, but that will be real lucky to find a used part for that.
JMS/.MN
04-16-2008 17:17:23
 Re: source for Hessston PT-10 MOCO used parts? in reply to hayray, 04-16-2008 16:40:53
Worthington Ag is at 1-888-845-8456- 11 yards, that number should give you your closest one.
Larry NE IL
04-16-2008 10:53:22
I bought all my parts from Maibach Tractor in Ohio. I would think any decent Agco dealer should have parts.
I have my PT 10 for sale if your interested.
E mail should be open. Or call
(630) 774-2087
