JD 7000 Planter Units
fergienewbee
04-16-2008 05:03:35
I found some 7000 planter units for $225.00 each. I have a few questions.
1. Are plates still available?
2. Can I clamp them to any tool bar or do I need a 7000 bar?
Any other help or pitfalls to be aware of would be appreciated.
Larry
paul
04-16-2008 11:49:31
 Re: JD 7000 Planter Units in reply to fergienewbee, 04-16-2008 05:03:35
JD 70 & 71 units drive off the closing wheel.
IHC 295, and some older models, drive off the closing wheel.
AC made an old & a newer style that drives off the closing wheel. Sorry I don't know the numbers.
The JD 7000 you mention most are plateless, but there were some plate style sold - more rare. Several folks on ebay & elsewhere do modify a drive system to turn them, so it is certainly possible. But not just bolt on & go - you would need to set up a transmission & chain drive from somewhere.
--->Paul
LA in Wi.
04-16-2008 06:28:29
Make sure those meters are plate-type or plateless. If plateless, take off the black plastic cover (held on with 3 1/4" bolts). Now you can see what condition the backing plate is for wear or rust...you will see 2 "speed bumps" and a brush. If the speed bumps are grooved or rusted the backing plate should be replaced. The fingers wear on the bottom side, so you have to turn off the big nut to get at that evidence. The brush WILL need replacing, hike over to the JD dealer and buy some and install them yourself; make sure the new brush is fully seated. The fingers will show a flat spot if worn enough...if you can"t see any flat spots, you might be good to go here. If worn, go buy a whole finger set; buying individual fingers is not the way to go and the springs are probably weak anyway.
Now is the time (with finger set removed)to turn the shaft by hand to see how the belts run...if things run smoothly chances are the belts might be OK. If belts seem stiff, they have to come out or you will break them at the other end of the field (Murphy"s Law). When reassembling, make sure the finger set is fully seated, then the big nut needs to be finger tightened, then turn the nut about 1/8 more, put castle nut cover over nut, insert cotter key and bend.
Now check that black plastic cover around the bolt holes (5 of them)for cracking; if cracked or broken, buy new ones right now.
See if you can turn meter by hand, should be a little resistance. Put meter on planter and hope for the best.
You really need to have someone who knows what they are doing for final assembly so you can plant with assurance that you will have a good stand of corn. There are machines now made for testing those meters "at speed" and they are great for knowing how the meter will do for accuracy.
$225 is a high price if you are talking about just the meters...maybe you got the hoppers also?
And the best advice I can give you is READ THE OPERATOR"S MANUAL. Then read it a second time.
Not being a smartbutt here, but you will understand if/when you have a train wreck in the field.
LA in WI
fergienewbee
04-16-2008 06:06:40
Gary;
I'm assuming these won't work on a tool bar, like the closing wheel driven ones will. Correct? Please excuse my ignorance--and thanks for saving me some money, I think.
Larry
IaGary
04-16-2008 11:24:53
 Re: JD 7000 Planter Units in reply to fergienewbee, 04-16-2008 06:06:40
Yes that is what I am saying.
You can ask the seller but I don't think you can drive them off a closing wheel. 7000 units were made to drive off of a shaft with chain drive off of the plantr transport wheels
Would be tuff to put them on the toolbar without all the transmission gears and so on.
Doug in IL
04-16-2008 05:47:03
There were plate type 7000's made. There used to be a few around here. The owner's manuals have a whole section on plate selection, planting rates etc. The plate type 7000 planters will bring considerably less money when one comes up for sale.
IaGary
04-16-2008 05:27:27
If they are 7000 units they have finger pickups and no plates are needed. There made have been some made with seed plates but I have never seen one in this part of the country.
They drive off of a drive shaft from the transport wheels and not off of the closing wheel.
Now if you have the #70 units then they drove off of the closing wheel.
Gary
