Possible Sub for Allis Bal-Pak Bearings
Tony
04-20-2000 19:20:35
For all the ugly background, see my earlier posting "mystery disk bearing". If you are cursed with an Allis disk using bal-pak bearings (sealed cylindrical untis 3" OD, 1" round ID, 2.5" long, and $112 ea!!), I may have a solution. My local farm store carries a disk harrow bearing type W208PP5: 3.14" flat OD, 1 1/8" square ID, extended inner race, triple sealed). I cut in half a cat2 to cat1 toplink bushing, filed it a bit, and pressed (hammered) it into the ID. The original saddle clamps tightened well around the slightly larger bearing OD. I used 1" flat washers to build up the length from the 1.75" inner race to the original 2.5". So far (1 whole day) so good. Total cost, under $18. If necessity is the mother of invention, poverty has to be the father. - Tony.
