plow
ikepieman
04-14-2008 08:40:16
I need some advice as I am looking to buy a plow. I will be using my Ferguson TO35 to pull the plow and from what I gather, it is capable of pulling a two bottom. I"m looking at the older dearborn, ferguson, etc. plows. My questions are what should I look for when buying the plow? I"m worried about replacement parts and what to look for as far as sprung or bent plows? Lastly, I would appreciate any suggestions as to what would be my best option. As you can tell i"m new to this and need to keep it as simple as possible. Thanks. Bob
Leroy
04-15-2008 14:26:59
 Re: plow in reply to ikepieman, 04-14-2008 08:40:16
Look for a flat bar type beam plow instead of a curved cast beam plow, they will be newer and more likely to have the replaceable blade throwaway type share that is what is more readably avaible as the older plows with the blacksmith sharpen type share that will cost more per share than the plow is worth and never buy a plow without coulters, they will never work correct, people that think they work OK without do not realize how much better they work with the coulters. Pick a Ford 101 or a John Deere as they are the best, Newer oliver is also good and have never seen a IHC with a 3 point hitch.
ikepieman
04-14-2008 22:23:07
thanks for all the great advice as this should help with my search. bob
8N'r--WI
04-14-2008 14:10:05
Ike---like others have said---get a 2-12 or 2-14.
If your tractor is in good shape, it should have no problem pulling either plow.
As far as what to look for, I would make sure the plow had useable shares and having the tail wheel or furrow wheel is a must have.
The jointers or coulters are not a necessity unless you are breaking new sod.
If you need to replace the shares the old "fish hook" type are available but very pricey so if you can find a plow with decent sharp points on the shares that are still useable, that is a plus.
If you have to keep the plow "original" you will find vendors that have "NOS" plow points available that will cost you more than you will likely pay for the plow.
There are a lot of Dearborn and Ferguson Plows for sale so don"t be in a big rush to buy the first one you run across.
You can also buy original and repro manuals for both Dearborns and Fergusons online.
HTH--good luck--you will have fun plowing.
Tim
Fred T. Hart Jr.
04-14-2008 10:14:12
I also have a TO-35, 1957 model, I have the factory 3-12" plows that came with the tractor new.
The 3-12" plow set is a load for the little Fergy. I would get either 2-12" or 2-14" plows for the tractor. If you can find a set of plows that have the auto trip, good chance they will not be sprung as they trip, if you hit a rock or root and do not tear up the plow.
I also like the field cultivator plow that ferguson made, I have one and it's a great plow as it leaves the land flat, no plow furrows.
You may have to turn your Carburetor power fuel adjustment out about 1/2 round when you start plowing. You do not want any hesitation as plows enter ground.
This old plow listed on ebay looks just like my 3-12" set only with the third plow off. Note it has all the options, wing extentions, colter scraps and trail wheel.
Link
Note item called Ferguson Tiller, this is what I have for breaking up soil, will not turn over dirt, but its like a small Chisel plow, works great, I use it most of the time, then disc behind it.
Link
Good luck, will need good points on plow to get it to suck into dirt,
reichstall
04-14-2008 08:46:16
i too am new to it i got a 2 bottom allis model 70 plow to go with my b the general talk was a b cant do a 2 bottom but it did. there is real art to getting it to furrow though which i have not yet mastered. but it is fun. i seen the plow you mention and there is a store called agri supply which seems to have a large supply of parts so i wouldnt worry so much about parts. the plow is the real promblem just my obeversion. jim
steveormary
04-14-2008 17:14:20
 Re: plow in reply to reichstall, 04-14-2008 08:46:16
We pulled 2-14's starting first with a new TE20 and later worked thru a TO30,641 Ford and a Ford 800. No problems.
steveormary
