Center line of draft on semi-mount plow
Randy-IA
04-13-2008 19:20:39
Hi All , I'm confused about that . On the pull type plows according to one owners manual the rule is one quarter the cutting width of one bottom measured to the left of center of the total cut of the plow . But with my Oliver 565 semi mount by setting the drawbar of the plow where it say's to the centerline of the tractor is lined up nearly with the centerline of cut but the steering head pivot point of the plow is actually about four inches to the left of center of the plow . How does draft work through a semi-mount ? Is the frame such that it pulls differently than a trailer type plow ? I feel like I should be lining up the center of the tractor four inches to the left of center on the plow in line with the pivot point . BTW it's a 4X16 with speedex bottoms . Thanks for any insight into this . I have to be missing something here because it doesn't make sense with what I know about the pull types . Thanks ! ...Randy
Sunspot
04-23-2008 10:57:53
 Re: Center line of draft on semi-mount plow in reply to Randy-IA, 04-13-2008 19:20:39
Thanks to all that posted advice on plowing.
ICH, Thanks for the drawings.
I did my first time on a plow Sunday. It looked OK but now with the newer information, I may be albe to do a better job.
ihcploughman
04-21-2008 11:48:53
I'd like to explain line of draft of a plow. Please refer to the link to the diagram. The red dots are the center of draft of each plow bottom. This point is usually one quarter the width of the bottom to the right of the shin. This can vary for different moldboard shapes and different soil conditions. So then you simply draw a line through all the plow bottoms and the middle of the line is the center of the draft of the entire plow.
Now here is where people get confused. You can hitch any width tractor to any width plow as long as you follow the attached diagram. Point C is the cener of draft of the plow, Point B is the rotation point of the semi mounted plow or the clevis or hitch pin of the pull type plow, and Point A is the center of pull for the tractor. These three points must line up or else you will have steering problems. You have all seen the guy with an antique tractor pulling a two or three bottom at a plow day and he has his front wheels turned 45 degrees and he is fighting the steering wheel like hes in a race car. That person didn't get points A, B, and C lined up. Now there are limitations to this which is in my next post.
ihcploughman
04-21-2008 11:58:36
 Re: Center line of draft on semi-mount plow in reply to ihcploughman, 04-21-2008 11:48:53
Here is the limitation to my theory. The arrow pointing downward is the summation of soil forces on the plow. If the ABC line came in line with soil force line (narrow tractor with wide plow), the tractor would be pulling all side draft from the landsides of the plow and the plow would veer to the right. Now, if you hitch a wide tractor to a narrow plow, you add side draft to the plow for the landsides to absorb. If your landsides are worn, or your vertical hitch is wrong, or your shares have inadequate suck, the plow may not stand the extra side draft and veer to the left.
Moral to the story: all that garbage about "dividing side draft" in plow manuals is just a dumbed down version of making points A, B, and C line up. Have a nice day.
Bret4207
04-14-2008 15:54:17
Hugh- I would truly love for you to sit down and write out how to adjust the various types of plows. I've heard a lot of guys say just what you have, but none have ever gone into detail about how to do it.
Hugh MacKay
04-18-2008 03:01:33
 Re: Center line of draft on semi-mount plow in reply to Bret4207, 04-14-2008 15:54:17
Bret: I don't consider myself a top of the line plowman. I've studied this one for a lot of years, had some tremendous coaching when I was a young man. The single biggest problem most newcomers encounter is they think the moldboard plow is a simple digging device with no real scientific adjustments. That gets most folks in trouble, the plow is actually one of the most sophisticated farm implements we use.
When I took delivery of my new semi-mounted plow, I figured my two top mentors would disown me, they being trailer plow guys, and probably two of the better plowmen in our county. Those two guys had entrusted me with their respective farms. I was busy finishing off the building of a barn before winter, along with milking 100 cows. My dad was away, so I left the tractor and plow under the nose of George. I knew he couldn't resist a new tractor with cab and a new plow. I was right, 4 days later he was looking for diesel , and had burnt roughly 100 gallons at that farm. I went with my pickup to fuel him up, he told me he was a full day plowing the first two acres, he had to adjust wheel tread then he had to adjust plow. That same 5x16 semi-mounted plow pulled very easily behind 656D. Over the years, different farmers had a crack at operating that setup and remarked how easy the plow pulled and how well the 656 pulled it.
I've gone to a lot of plow days and plow clinics. I remember once a guy showing up with a 9000 Ford and 5x16 semi-mount plow he was having problems pulling. I did get to operate that one, and couldn't believe a poorly adjusted plow could demand so much horsepower.
I would never attempt to write a book, it would be a lot of detail. I think this could be best handled through vidio, and I suspect it has been already done.
Hugh MacKay
04-14-2008 04:01:51
Randy: All plows that load the tractor to it's limit must be centered using wheel tread. These old habits come from using trailer plows that probably used less than 60% of tractor rated pull and with those you just adjust the drawbar to suit. Side draft for example probably wouldn't bother a Farmall SM pulling a 2 bottom plow.
Once you get to 85% of tractors rated pull you have a whole new ball game. Wheel tread must be adjusted to give center line of draft at center of tractor. There are charts and I'd give it to you, except I've lost my copy. It gives you distance from center of tractor to inside of right rear tire for each and every configuration of plow. With trailer plows you probably have 4 inches of leeway. Mounted and semi-mounted plows have to be much closer to exact setting.
I've plowed thousands of acres with both trailer and semi-mount. Once you go semi-mount the tractor must be adjusted to suit the plow, not the plow adjusted to suit the tractor. If you do get the plow adjusted to suit the tractor, it will probably be a miserable tractor to steer, if bad enough it may even turn the tractor crossways.
If you adjust the tractor to suit the plow, here is what can happen. I pull 2x12, 8" deep with my Farmall 130 at 4.5 mph. In the past I pulled 3x16, 8" deep with Farmall 300, again 4.5 mph and I pulled 5x16 semi-mount, 8" deep with Farmall 656, 16.9x38 tires, no chloride or wheel weights, and again 4.5 mph. A perfectly adjusted plow and TRACTOR work much easier than most people would have you believe. From my travels, and experience, 85% of all folks using plows are doing it with tractor or plow out of adjustment. When I read a thread and the guy is telling us he needs 135 hp to pull 4x16 in his heavy clay, I shake my head and say,"there is another guy doesn't know how to adjust his plow and tractor."
Randy-IA
04-14-2008 19:14:24
 Re: Center line of draft on semi-mount plow in reply to Hugh MacKay, 04-14-2008 04:01:51
Hi Hugh , I don't think I've gotten to 85% pull yet with my plow except in old alfalfa sod . My 1755D mostly just plays with 4-16'S so far , but last fall I did a 20 year old alfalfa field that gave me fits . I tried different drawbar settings with no luck . I'm thinking the landsides need to be made new so I'm getting four of those this week . But should I follow the owners manual or not ? Should I assume that the centerline plus four ( one fourth of 16" ) is just that and set the tractor and plow that way ? I had a heck of a time with the plow tailing into the furrow wall last year no matter how I set the tailwheel . It was obvious the plow was running crooked but nothing we did seemed to help . The right wheel is now set at 31 " from center . That's right at what the Oliver owners manual calls for ( 565 Oliver 4-16" ) . The rule of thumb in a owners manual for a JD pull type 4-16" would call for 36' wheel spacing to centerline of draft ( 16"x4=64"/2=32"+4"=36" from furrow wall to centerline of cut ) Which one would work best ? Obviously making adjustments at a plow day lessens the amount of plowing I can do . So should I set the tractors wheels for 31" or 36" and/or set the plow for the rule of thumb ? I know this is as clear as mud but I'd really like to do it right . Thanks ! ...Randy
Leroy
04-15-2008 14:46:54
 Re: Center line of draft on semi-mount plow in reply to Randy-IA, 04-14-2008 19:14:24
Randy, that JD measurement is they are using the center of the tire as measure point instead of sidewall as the Oliver is using. And the cross bar for the hitch needs to be adjusted for to tread setting and when those are both set correct the top link mast will be centered to the tractor. If you want more information I can hunt up my manule for a Massey Ferguson plow and mine was for a 4-14" but it also had all the settings for a 4-16" and most of the tractors of the size for that size plow use bottom link sencing and you do not use a top link with those tractors. I do not know if the Pliver has top link sencing or bottom link sencing. Deere are bottom and Ford are top link. Leroy
Randy-IA
04-15-2008 18:47:32
 Re: Center line of draft on semi-mount plow in reply to Leroy, 04-15-2008 14:46:54
Hi Leroy , That won't be necessary about the manual . The oliver manual I have is what I should follow . My 1755 has bottom link sensing . The top link is only for a safety factor from the way I understand it . I can use the plow without it . I'm going to keep working on it . Thanks ! ...Randy
Leroy
04-15-2008 19:08:31
 Re: Center line of draft on semi-mount plow in reply to Randy-IA, 04-15-2008 18:47:32
The plows sold for bottom link sencing were sold without any provision for a top link, will do nothing for safty.
Hugh MacKay
04-15-2008 03:11:24
Randy: Wear parts can have a marked effect on plowing quality, I'd get those landside on before making much adjustment. The 31" centerline of tractor to inside of right rear tire sounds close. Ideal would be somewhere between 30" and 34" I would think.
I'm not about to question Oliver's manual, they do take a different approach on the writing from IH for example, which I am used to. I've seen too many Oliver Plows work well, to critize their manual.
Are you using a on land depth gauge wheel directly opposite the rear bottom. I've seen guys having great difficulty trying to controll rear depth of plow with the in furrow steering wheel. Not that the steering wheel didn't control depth, it throws other things off.
It's close to impossible for me 1,000 miles away, to tell you exactly what your doing wrong. If you go to plow days or plow clinics, latch onto some guy right up to speed on your equipment. These plow clinics are becoming quite popular. Get about 20 guys plowing with a team of well known farmer experts to help participants make the adjustments needed. The moldboard plow is a complex piece of equipment, probably from an adjustment point of view, more difficult to get correct than most other farm equipment. Bill is questioning my 85% figure, and probably what I should have said are 15% are doing excellent plowing 70% are striving to do better, not satisfied with their plowing and the bottom 15% don't give a damn, to them a plow is just a ripper. Those 70% (your group) are not satisfied, and this is exactly what is driving plow clinics. There were no such things when I started out, I just poned the job off on my dad or one particular neighbor.
Randy-IA
04-15-2008 19:11:04
 Re: Center line of draft on semi-mount plow in reply to Hugh MacKay, 04-15-2008 03:11:24
Hi Hugh , The landsides are worn about a 1/4" on the bottom of 1/2" thick material . So yes , I need to replace them . But - It's my understanding that the landsides are not supposed to even touch the furrow wall but be about 1/4" away .
No - I'm not using a gauge wheel but I wish I had one . I haven't noticed a problem with the rear wheel's depth control .
I am concerned about doing the best job possible . Even for plow day plowing . I had an experienced oldtimer follow me about 1000ft across the field on foot and all he could do is scratch his head . He said it was level all around and the rear wheel tryed it's best . I've measured the bootoms and the plow isn't bent or sprung that I can find . I'll get it worked out sooner or later . Thanks for the help ! ...Randy
billonthefarm
04-15-2008 05:15:20
I think I could generally agree with those numbers. Some guys are just naturals and some guys dont care and that leaves alot in the middle doing a adequate job. It takes alot of time to do a good job of plowing but if you dont you will pay for it the rest of the year just like you said. bill
Hugh MacKay
04-15-2008 05:38:14
 Re: Center line of draft on semi-mount plow in reply to billonthefarm, 04-15-2008 05:15:20
Bill: We agree, I know there are a lot of folks out there, striving to plow better. Farming is not any easy game anymore, lot of pressure on farmers time for matters other than plowing. My wife said to me the other day, "man works from sun to sun, a woman's work is never done." I think our modern day farmers are not a lot different.
Sure commodity prices are on the increase, but so are the inputs. I'm sure there are many guy out there with the between ear computer just a grinding as they plow, cultivate, drill, etc. Lot different from the old days when you sat back on the old open station tractor, singing a few bars of Wabash Cannonball, or what ever your favourite was. I had a neighbor tell me, my version of Wabash Cannonball above the 560 diesel had a way to go to match Roy.
JMS/.MN
04-14-2008 16:54:49
I"ve always respected your knowledgeable posts, but bring that 656 with a 5-16 plow to Glencoe, MN gumbo and set it 8 inches in the ground. Bring the noseplugs to keep out the smell of the burning clutch. I"ve seen 4020s with three bottoms behind, blowing smoke in that gumbo. Even where I live, lighter clay, no way a 656 would pull a 5-16 plow except on the road, no matter how it is adjusted. 706 on a 4-16 was common years ago.
paul
04-14-2008 10:00:04
Yuo are welcome to visit. :)
The 4-16 semi-mounted would pull the front end of the 85-90 hp tractor up off the ground in the right spots - and the front tired are liquid filled.
To plow alfalfa dad would use the 3-10 on the Oliver 88, with 2 chains and a tire hooked up to the H or 300 with mom driving. Couldn't pull it.
Pretty common to have 6-20 plows pulled with 180+ hp tractors around here.
I could often pull a 5-20 bottom plow with my 135hp, but not _always_. In fact, I'm looking for one, see how it works. But I won't throw the 4-bottom away. :)
A 4-20 plow can pull pretty hard, but it allows more trash to flow through so I save a trip disking or chopping stalks - seems like a good trade to me.
You get into the clay soils, and setting up the traction of one wheel in the clay furrow, a set of duals on the trashy surface, and set it to work so your town wife & her town galfriend can run the plow all fall - then you know what setting up a plow is all about. :) :)
All in fun. :)
--->Paul
paul
04-14-2008 20:00:18
 Re: Center line of draft on semi-mount plow in reply to paul, 04-14-2008 10:00:04
Man, was that typo filled. Sorry. Having a stressful day.
Dad plowed with a 3-16 on the Oliver 88, probably a 50 hp tractor. In alfalfa, had to add another tractor to get it through.
The soil around Glencoe is pretty heavy, but I can beat it in my fields. It just latches on to the plow, holds it down. Moisture can really make a difference.
Dad said he used every gear but 2 on that Ollie 88 to plow over the years. In our short season & wet ground, need to get it plowed, so I need to plan for the tough years, when it goes extra hard.
Maybe strip till will work out here some day.
--->Paul
billonthefarm
04-14-2008 06:00:41
To say that 85% of farmers dont know how to set a plow is a pretty big statement, dont ya think???? bill
thurlow
04-14-2008 08:15:39
 Re: Center line of draft on semi-mount plow in reply to billonthefarm, 04-14-2008 06:00:41
I don't think the word farmer(s) is anywhere in Hugh's post. I came along at the 'tail-end' of the trailer plow era.....around 'here', although I used an "H" Farmall with one for a year or two. Used 2,3, 4 and 5-bottom 3-point hitch ones, but when we went to semi-mount 5 and 6 bottom ones in the mid to late 60s, the whole world changed. Could set 'em at the shop and not ever make any adjustments in the field.
RodInNS
04-14-2008 06:36:06
I'd doubt if he's too far out with that statement actually. A lot of guys will get a plow relatively close and it will do half decent work, but I'd suspect that there are VERY few who actually get it dead right. I'm one of the many who don't put the time on it to get it exactly right, but close enough.... IN easy plowing I don't notice much difference, but when the going gets rough I do notice the plow laying over on it's side and a couple other things that would indicate that the center of pull is not correct.... and for the few acres I might be plowing at the time it's generally not worth the aggravation of changing the wheel settings or spending the time to get it set right. Keep in mind that I'm in an area where it's mostly livestock operations (as was Hugh), and there is probably fewer than 15% that understand the nuances of setting a plow up properly and probably close to 50% who have no idea in the world how to set a plow at all. For them it's purely hit and miss, or they have one way of setting it based on measurements. I remember one guy setting his up with a tape and linkage measurements....
The statement may not be true in an area where a lot of plowing is done, but I'd say it is 'here'.
Rod
Hugh MacKay
04-14-2008 09:43:43
 Re: Center line of draft on semi-mount plow in reply to RodInNS, 04-14-2008 06:36:06
Rod: Now that I have the time, I quite often get in the car and take drive down the county roads here in southern Ontario. It's not like your and my home turf where 90% of the land is forested. Here 90% is agricultural cash crop land. I don't have to drive very far to see a lot plowing and different plowman. Usually when guy does a mess on plowing the rest of his tillage is not much better. I don't have to see the guy plowing or even get out of my car to judge a farmer's tillage practices. If you see a guy in a 150 hp cab tractor, with duals, and his ride is so rough, he has to wear a hard hat to avoid concussion from hitting the cab posts, you know the tillage is damn poor. even if he's being moderately tossed around you know the tillage is mediocre at best. If his tillage is perfect the ride in that 150 hp tractor should be close to a Cadilac driving down the road past your farm. I never saw that a lot in Nova Scotia, I don't see it a lot in SW ON and I don't see it a lot when I go south of the border. I stand by my 85%
billonthefarm
04-14-2008 19:36:15
 Re: Center line of draft on semi-mount plow in reply to Hugh MacKay, 04-14-2008 09:43:43
So, am I safe to say that you think that 85% of the people that provide food and fiber for the world are, in your opinion, doing a poor job of farming? bill
Hugh MacKay
04-15-2008 02:14:30
 Re: Center line of draft on semi-mount plow in reply to billonthefarm, 04-14-2008 19:36:15
Bill: That isn't what I said.
Hugh MacKay
04-14-2008 09:41:50
tim[in]
04-14-2008 19:00:14
 Re: Center line of draft on semi-mount plow in reply to Hugh MacKay, 04-14-2008 09:41:50
From what i've seen of the pics of the plows they use at the plowing contests there is definitly an art to adjusting a plow that i think high tech will never replace.I always tried to get it so the plowed ground was smooth and flat and each furrow was turned over the same heighth and distance as the others so you couldnt tell which furrow was the first and the last. Some fields ive seen onefurrow would always be higher or lower.
RickB
04-14-2008 02:54:24
Center of draft is calculated the same regardless of plow hitch type.
Randy-IA
04-14-2008 19:25:38
 Re: Center line of draft on semi-mount plow in reply to RickB, 04-14-2008 02:54:24
Hi Rick , So 1/4 of a cutting edge to the left plus half the cutting width of the plow ( 16*4/2+4=36 ) is where I should set the wheels/plow for centerline of draft regardless of the owners manual ? That's what I think but I would like to have the plow set before getting there since the day is short ? Thanks ! ...Randy
