stan-hoist loader question
frkln
04-12-2008 20:19:04
my list cylinders on my stanhoist loader are leaking a little. who has the replacement seals or rebuilt kits for them????? look every place.. just cant weem to find them. i know they dont make the lift any more.. i just thought i would be able to find seals!!!
thanks
IaGary
04-13-2008 03:40:33
 Re: stan-hoist loader question in reply to frkln, 04-12-2008 20:19:04
Get your measurements on the seals and call these guys. They will have them.
frkln
04-13-2008 09:09:44
 Re: stan-hoist loader question in reply to IaGary, 04-13-2008 03:40:33
thanks for the info... how hard is it to rebuild those cylinders? always been kinda afraid to rip one apart!!!!!
thanks again
IaGary
04-13-2008 10:10:40
 Re: stan-hoist loader question in reply to frkln, 04-13-2008 09:09:44
Cylinders are put together in many different ways.
If you can show me a picture I can help out.
I have rebuilt about every style you can imagine.
The end that the ram comes out (head gland) comes apart someway. Some are threaded some have snap rings.
You can do it, just watch how you take it apart and put it back together the opposite way.
The seals on the piston are held on in different ways also but they all come apart.
Some that I have rebuilt were welded together. Cut them open replace all the seals and weld it back together.
Gary
frkln
04-13-2008 12:08:51
 Re: stan-hoist loader question in reply to IaGary, 04-13-2008 10:10:40
gary,
thanks, the ones on my lift have a snap ring, then you can see a pressed in ring containing a plastic ring..... the guy gave me some lift parts, looks like from a prior rebuild. looks like the seal from above, then a bullet shaped piece of alum with o rings on the outside and inside, then a bunch of other o rings in a bag, and a couple of rubber cups.
i will try to post pics.
the other cylinder is leaking from around the fitting going into the cylinder.. but i figure as long as i am getting parts to fix one, should do both of them!!!!!
thanks again for the help
