Post Hole Digger for MF135
RAD
04-20-2000 13:30:03
I have need for a post hole digger for my MF135 diesel. I'm not sure what kind, model or length auger to purchase. Where's the best place to find a used one and how can one be sure it is in working order?
Also, I have recently acquired 2 brush hogs; a Field General made by Taylor/Pittsburg and a King Kutter. Which one should I keep?
SCOTT STAMY
04-20-2000 14:33:06
 Re: Post Hole Digger for MF135 in reply to RAD, 04-20-2000 13:30:03
SIR:
I WOULD RECOMEND BUYING A BUSH HOG BRAND POST HOLE DIGGER. THEY OFFER 3 DIFFERENT MODELS. I WOULD RECOMEND THE MODEL PHD 2102 AG. UNIT. THIS UNIT HAS SHEARBOLT DRIVELINE PROTECTION AND YOU HAVE A CHOICE OF DIFFERENT SIZE AUGERS. DOUBLE FLIGHT AUGERS ARE BEST REQUIRING LESS H.P. TO OPERATE AND CLEAN THE HOLE OUT WELL.
THIS UNIT WILL FIT BOTH CAT.1 AND CAT.2 3PT HICHES.
YOU NEED TO DETERMINE HOW MANY HOLES YOU WANT TO DIG, HOW BIG OF HOLES YOU WANT TO MAKE AND IF YOU PLAN TO USE THE UNIT COMMERCIALLY.
AS FOR USED UNITS THERE ARE MANY UNITS THAT YOU CAN'T GET PARTS FOR OR ARE JUST WORE OUT.
HOPE I'VE HELPED YOU OUT.
