Wheel bearings in 555H plow
Randy-IA
04-10-2008 10:43:27
Hi All , I finally had time to work on the 555H I bought last spring . I found that the front wheel bearings are shot ( along with the rear wheel sleeve ) . I tried adjusting them but that didn't work . I didn't take them apart . I asked the parts guy at JD if off the shelf wheel bearings for another application would fit such as trailer bearings . His answer was that he thought they would fit but wasn't sure . Has anyone tried this ? If so is it less expensive than JD parts and do you have the bearing numbers ( bearing and cone if not a set ) that fit ? I'll probably get the seal from JD unless there's a cheaper version someplace else . Thanks ! ...Randy
B-maniac
04-13-2008 14:39:56
 Re: Wheel bearings in 555H plow in reply to Randy-IA, 04-10-2008 10:43:27
Any reputable auto/equipment retailer should be able to "cross-over" your original # and find a match in one of the three or four top name brands.
