Kverneland MI 3-18 plow
Robert Cornell
04-10-2008 08:04:20
Any reason I should be afraid to try and pull a Kverneland 3-18 plow with my 826 Farmall (90 HP German Diesel with good TA)? This is a fully mounted spring trip plow with the Kverneland (long moldbord) bottoms on it. I can pull a semi-mounted 4-16 710 IH without any real problems but wanted to be sure about these Norwegian bottoms fully mounted.
Thanks
Robert Cornell
04-10-2008 11:52:24
 Re: Kverneland MI 3-18 plow in reply to Robert Cornell, 04-10-2008 08:04:20
Thanks guys, I figured as much. Best crop ever grown here (Washington Island, WI) is rock. That is why I am using the auto reset plows. Had a trip bottom, but spent more time backing up than going forward.
RodInNS
04-10-2008 10:56:57
Should be about half a plow for that tractor..... Be careful you don't twist if up of you have rock, and keep the spring trips properly freed up. An 'AB' with auto reset's is a more popular plow around here if you have rock. Just drop it and drive...
Rod
Mark W.
04-10-2008 10:05:26
Hooker up and get after it, great set up. I've pulled the same behind a 756 diesel in some pretty wet ground and it does a great job!
