Vicon mower
farmall650
04-08-2008 15:04:09
how much oil and what weight does a model 240 use
KEH
04-08-2008 18:40:36
 Re: Vicon mower in reply to farmall650, 04-08-2008 15:04:09
Use 80-90 gear oil in both cutterbar and gear box. To fill cutterbar, put cutterbar in upright position. Unscrew filler plug which on top center of cutterbar, I THINK between 2nd and 3rd cutterheads. Fill until oil runs out. DO NOT OVERFILL. The machine will do better a little low on oil that high. If it is overfilled, seals will blow in the cutterbar and leak oil. Replacing the seal involves separating the cutterbar into the 2 halves.
To fill gearbox, put the cutterbar flat on the ground. Take the oil plug out and fill until the oil runs out, replace plug. To check oil level in gearbox, take out plug and look in the gearbox.
To check oil level in cutterbar,Put cutterbar in upright position. let sit overnight so the oil will run to the bottom. Remove plug, check oil level visually. If you don't see oil but can reach in and touch oil with matchstick sized stick, oil level is ok.
KEH
farmall650
04-09-2008 16:04:31
 Re: Vicon mower in reply to KEH, 04-08-2008 18:40:36
Thanks
