Planter plates
Ark. Red
04-07-2008 19:16:58
Can anyone tell me if the planter plates for a cub tractor will work in the planter for a super A or 140 tractor? Those I have seen advertised on Ebay look the same as some I am using now with my 75 model IH 140 set up. Also would like to know if anyone knows the number of a planter I have and have used on same tractor. It is an all metal planter but has two side by side hoppers, one for corn and one for peas.
mweverett
04-10-2008 19:31:33
 Re: Planter plates in reply to Ark. Red, 04-07-2008 19:16:58
The hoppers, hopper bottoms and the adapter casting they lock on to, both seed and fertilizer are the same for cub and A-140 mounted planters. Everything else is different for the different size tractors. These hoppers are common to the tool bar mounted multi unit planters of the same vintage, on up to the 80's I reckon. I have a 174 Runner Planter with a type C Duplex Hopper, really nice for the veg garden. They use a conical ring seed plate suspiciously like a Cole/Covington planter. I have wondered if the C in Type C means cole or covington.
SuperA-Tx
04-09-2008 06:08:14
I compared the plate numbers in the Cub 174 planter book and the 179 Blackland Planter used on the SA and 140 Farmall and both books show the same numbers on the plates, combination plates as well.
Conclusion, Cub planter plates will work for your SA or 140.
ark-rred
04-09-2008 17:48:37
 Re: Planter plates in reply to SuperA-Tx, 04-09-2008 06:08:14
The number I found on the side by side planter hopper is an IH # CPC 5130. The one plate I have that works is a pea plate # CPB 5016.
The planter hopper I am using is a IH # H478563R1 on the base that the fiberglass hopper sits on and the actual seed plate carrier is 621704R2. The piece you see when you look down into the seed hopper that spreads the sead out says corn & beans # 621726R6. Could this be a McCormick-International one row No.184 planter w/International hopper mnfg. 1968?
Ar-Red
04-09-2008 16:05:50
thank you very much. Where is the best place to get a manual for the planters you are refering to?
SuperA-Tx
04-08-2008 06:35:00
In the 179 Blackland Planter manual it shows a picture of a "type c duplex hopper" that is divided into two sections. I wonder if this is what you are talking about? Says you can plant two kinds of seed such as corn or beans either alternately or both at the same time.
As far as the plates for a cub planter working on a 170 planter for a 140 I have no idea if they would fit or not.
Your planter a side mounted planter that also uses the 101 fertilize unit?
Ark-Red
04-08-2008 19:21:05
 Re: Planter plates in reply to SuperA-Tx, 04-08-2008 06:35:00
Yes, it is the normal set up for international Harvester 140 or Super A cultivators. Seed plates that run in it look just like the cub seed plates advertised on ebay for sale. The nice thing about the old side by side planter is you can actually see the seed as it is coming out of the seed plate and into the seed horn and tube. You know positively you are putting out seed.
SuperA-Tx
04-08-2008 21:10:39
 Re: Planter plates in reply to Ark-Red, 04-08-2008 19:21:05
I have ten seed plates for the 179 planter for my Super A and so I compared the numbers on them to the ones listed in the cub manual and not any of them matched. My manual for the 179 is at my work but tomorrow I'll compare all the plate numbers listed in both manuals.
I have plate numbers 7932, 7933, 7934, and 7937. One spacer P01978, and three seed plates that all have the same number but have differant size seed holes, P01979.
Below is the url for the cub planter. You will have to copy and paste the url.
If you have a manual you can compare the numbers yourself.
http://www.cleancomputes.com/Cub/Cub%20Implement%20Manuals/Cub-174%20Runner%20Planter/Cub-174%20Runner%20Planter.htm
bryanandtrinity
05-21-2008 18:58:30
 Re: 101 fertilizer unit in reply to SuperA-Tx, 04-08-2008 21:10:39
Where would I find replacements for this? Are there aftermaket parts?
