IHC #8 plow parts needed
JOE-ILLINOIS
04-07-2008 18:26:16
Hi, I am looking for the little ubolts that tie the rods together on the levers, are they still available, thanks Joe
Randy-IA
04-10-2008 15:41:14
 Re: IHC #8 plow parts needed in reply to JOE-ILLINOIS, 04-07-2008 18:26:16
Hi , I don't think they are available anymore . Your best bet is a salvage yard or find one before the junker does and snatch those . I have been lucky enough to get mine loose with a lot of PB Blaster and patience . A little propane heat didn't hurt either . I haven't looked yet but I'm going to need the wire for the levers that those clamp on . I have three #8's that I'm having to fabricate parts for . These are simple plows and easy and cheap to work on . A far cry from my JD 555H or 565 Oliver semi-mount . I have less than thirty dollars invested in the one plow I have ready to use . That includes three new to the plow tires mounted on the rims . The tailwheel tire was from my stock of small trailer tires ( 4.80x12 ) and the front tires where free for the mounting with the purchase of new tubes ( Tiger paws ) at the local tire shop . I made new j-bolts ( Called a lever plunger in a old parts book ) for the adjusting lever quadrants out of 1/2" round stock bent and drilled using the old springs . I tightened the hubs with a drill and some creativity . Took apart the clutch , cleaned and re-lubed it , now it works perfectly ( so far ) . I have a stock of 13 QD ( Quick detach ) shares for it some of which are actually sharp . But the local blacksmith sold his trip hammer so he won't sharpen any more shares :( . So now I have to learn to be a blacksmith too . I have the forge but no anvil so they might sit for a while . The other two plows have plow chief bottoms which are even harder to find points for . Good luck with yours ! ...Randy
