3-point rear mounted blade
Gary A.
04-07-2008 14:19:32
I have a 3-point rear mounted blade that I need help in identification. Its original color is gold or slightly dark yellow, has a model no. 1101, and make name is WINPOW---. Could it be WINPOWER? The blade is 8 ft. in width and can be tilted forwards or backwards, four different blade pitch settings, by loosing a set of 4 bolts. These bolts are inserted to a three sided piece which is clamped around a four sided, three inches in width hollow bar. Each side of the hollow bar is 1/4 inch. It is located on the back side of the blade. The blade can be turned in any direction by removing the pin upwards, and rotate the blade, manually. There are two different width settings on each side to use when inserting the lift arms of the three point hitch for hook up.
