cyclo 400
Iowa Ron
04-07-2008 05:34:31
will a regular corn drum work to plant sweet corn seed on a cyclo 400 ih planter?????
Iowa Ron
04-07-2008 10:02:36
 Re: cyclo 400 in reply to Iowa Ron, 04-07-2008 05:34:31
some one told me the seed will blow through the holes in the drum
RickL
04-07-2008 16:27:50
 Re: cyclo 400 in reply to Iowa Ron, 04-07-2008 10:02:36
yes it will work fine did it for years with my 900 series. turn the air down little yes you will have a few blow thru but couldn't tell it by the stand. GO FOR IT IT WILL WORK
Allan In NE
04-07-2008 12:24:52
Check your seed drum. Holes should only be like an 1/8" like Gary says.
Maybe your drum is completely worn out.
Allan
Iagary
04-07-2008 11:13:24
The holes aren't that big are they?
Neighbor plants it with his. Holes are only about 1/8 inch arn't they.
Gary
Iagary
04-07-2008 05:47:44
If you don't care about a double seed drop once in a while it will work fine.
If you want it more accurate on spacing set the brush closer to wipe off the doubles.
Yes it will work.
Gary
