Seed Firmers
Joel H.
04-06-2008 15:35:58
I am thinking about putting seed firmers on my planter this spring. Anybody have these on their planter? How do you like them. The planter I want to put them on is a 5100 white. I am surprised that most of the after market planter attachments are not available for the 5100 white any more.I'm not even sure if I can get seed firmers for this planter. Everything seems to fit 6100 and newer planters. The early seed firmers clamped to the seed tube with a hose clamp & tie strap. I've heard that this can distort the seed tube and effect seed spacing. The new ones have a bracket that they use to attach to the planter, which could affect the availability for older planters. Any advice you can give me is appreciated.
RickL
04-07-2008 05:26:27
 Re: Seed Firmers in reply to Joel H., 04-06-2008 15:35:58
save your money. Put another set on Kinze takes drilling 64 holes. Seen them after couple years use busted cracked etc. Forget about them
Iagary
04-07-2008 04:22:00
I bought a Kinze planter about 6 years back. It had Keatons on it.
Some fell off over the years and I never replaced them. The rows with or without the firmers were unidentifiable when the corn came up.
Save your money. I would never buy them again.
They are bound to drag some of the seeds and screw up the spacings.
Now if I were looking for a way to place starter in the row then I might use them.
Gary
MNGreybeard
04-06-2008 16:16:49
I have them on a CIH 900. Supposedly they press the seed into the moist dirt in the bottem of the seed trench. I guess the only way to see if they help would be to plant some with them, some without. As they're not easy to get at, I don't think I'll do that.
