Bucket for Massey Ferguson 35
Thomas S Hamito
04-05-2008 22:04:12
The tractor currently has a after market Superior products bucket that is no good. THe frame work attached to the tractor is fine. The bucket is shot. Any ideas where to get a bucket and estimated cost
Jerry/MT
04-06-2008 12:57:32
 Re: Bucket for Massey Ferguson 35 in reply to Thomas S Hamiton, 04-05-2008 22:04:12
Is the bucket repairable? If you can weld you might be able to repair it or you can take it to a weld shop and have them repair it.
Any old bucket with the same width and approximate height will work IF the existing mounts to the loader frame are good and can be removed from the old bucket and welded to the replacemnt bucket. You"ll want to make sure that if you put the old mounts on a different bucket, the location of the mounts will have to have the same position on the new bucket as a the old bucket (height above the bottom of the bucket and distances from the bucket edge).
Try a tractor salvage yard or a salvage yard for construction equipment.
