Fuel consumption question
HAYBOY1
04-05-2008 18:23:53
I recently purchased a JD 4250 MFWD with the quad range in it. I have a 4430 as well but I noticed the 4250 uses fuel at an alarming rate, and I have hardly used it. I know that the 4430 would burn about a 1/3 of the same amount. Any thoughts as to why? Or is this normal for this model? Thanks in advance, Mike
low budget
04-05-2008 18:37:05
 Re: Fuel consumption question in reply to HAYBOY1, 04-05-2008 18:23:53
Start by checking for fuel leaks,including leakage of fuel from diaphram pump and injector pump into crankcase. Replace fuel and air filters, and check injection pump timing. I've found alot of tractors timed late, will make them run hot too.
HAYBOY1
04-06-2008 14:28:29
 Re: Fuel consumption question in reply to low budget, 04-05-2008 18:37:05
I will. thanks
