planting?
marshall grn
04-05-2008 15:50:19
I was picking up some seed plates today at the local mfa and was going to buy some soybean plates and the guy working said i could use my corn plates for soybeans? does anyone else do this? or should i get some bean plates? just putting in some food plots with a 494 4 row JD planter, thank you
jbruce
04-06-2008 19:31:06
 Re: planting? in reply to marshall grn, 04-05-2008 15:50:19
I tried several bean plates on my IH planter and they all strung beans. Went to 24 cell round kernel corn plates and did a beautiful job.
paul
04-06-2008 12:21:06
You might want a corn seed every 6 inches or so apart, and you might want a bean seed every 1 inch apart.
Bean seeds may be 1/2 the size of some corn seed, do you have a corn plate that will fit 2 or even 3 bean seeds per hole????? This would double your planting rate.
If you can change the speed on your planter that much to make the corn plate work; or plant 2x over the same area down the middle of the first rows, whatever - to get that many more seeds per acre.
For a food plot probably doesn't make much difference, you don't need ideal seeding.
But you would be looking to put 6x as many seeds down, beans vs corn, typically. As a rough guide.
--->Paul
johns48jdb
04-06-2008 04:45:53
could you speed up the planter to make up this difference. my grandfather always set the planter up by running it on the gravel drive way for a few feet and looked at the number of seed and their spacing and set the planter to his liking.
Maark
04-05-2008 17:29:23
You could use your corn plates, But, the seed will be spaced several inches apart instead of 1 inch like a bean plate.
