you have received good info. Plowing is a bit of a art and it takes a while to get everything adjusted. However, just as with different trucks, cars, tractors, etc: some plows will work smoother than others. What tractor and plow comb do you have? Another factor that is often missed is right side wheel spacing. You can not have the front tire adjusted out farther from center line of tractor than the back tire. If so and you try to keep the front tire aganist the furrow your tractor will be running at an angle to the plowed furrow all the time. I know this sounds wild, but take a long straight 2x4 and place it up aganist the inside of the right side back tire, if there is a space between the front tire and the 2x4 your front tire is spaced too far out, bring it in so it is equal to or closer to center line of tractor than back tire. Believe me this will help you as you try to plow. The three plows, if set right will follow the tractor almost like a trailer. Both lower arm chains will be loose and the plow will follow straight behind tractor. May take you a while to get to that point and just plowing small plots, you may never get there. It takes a while for the plows the clean themself's if they have rust, will plow better when they have a high shine. also if you do get it right and all is good with the world, write down the some basic numbers. Length of top arm, height off ground of left bottow arm and right bottom arm. So next time you hookup to plow you will have everything set and you can enjoy the experience. Good luck, as you see I enjoy plowing I have a TO-35 Ferguson with factory 3-12" plows and they do smooth level work.
