mm manure spreader
glr62
03-31-2008 19:05:16
what kind of wood to restore wooden spreader and what kind of rivets
Leroy
04-01-2008 13:16:43
 Re: mm manure spreader in reply to glr62, 03-31-2008 19:05:16
Restore means make show ready and if that and a MM spreader is a show type of iten, then pine wood with tractor paint and rivits, no oil. Recondition means make work ready and in that treated pine with carriage bolts all the way, screws you would have to make other holes in the frame and you do not want to weaken the frame in any way
tg in VA
04-01-2008 09:11:32
Pine lumber painted with used motor oil works just fine. "Treat" the lumber with another aplication of the used motor oil every 5 or 8 years. Carriage bolts for the floor so the apron won"t snag on the bolt heads.
jal-SD
04-01-2008 06:08:40
If its going to be used, I'd price some of the "plastic" or composite lumber thats out there. It won't rot out like wood will. I don't think I'd use rivets, carrage bolts or "deck" screws that work in metal (might have to drill pilot holes) where ever possible. (My $0.02 worth. jal-SD)
