minnesota spreader floor
FUMBLEFARMER
03-30-2008 18:59:05
What kind of wood were the old spreader floors made out of?Almost seems hard like oak but I think that would rot easy.May want to put new floor in my mn spreader.Not sure its worth it though. Also wonder if the little pullys in the needles of the 14t baler, where the eye is ,are supposed to turn freely?Appreciate any help .Fumblefarmer
tg in VA
04-01-2008 09:17:26
 Re: minnesota spreader floor in reply to FUMBLEFARMER, 03-30-2008 18:59:05
Why go to he the expense of treated lumber? Plain pine treated with used motor oil lasts forever. I have an old International, retired many years ago, that has never been under a shelter. The plain pine floor treated with used motor oil (poured on and spread with a brush, top of boards only) is still good after 25 years.
rrlund
03-31-2008 06:35:17
Are you restoring or using? If you're using,I'd use treated plywood.Then soak it good with used oil after you get it installed.
FUMBLEFARMER
03-31-2008 20:02:12
 Re: minnesota spreader floor in reply to rrlund, 03-31-2008 06:35:17
Thanks that sounds good.
