Farmall Kirk,
04-01-2008 03:32:31
Re: Farmhand stacker, in reply to steveormary, 03-31-2008 20:46:28
Hi Steve, It's Kirk, I was looking at that farmhand stacker? And was thinking that I had to have a person to help me, I guess you take the head, or loader off, sit it aside, Then you jack the back up, And then you go for the Hyd pump, the frames have pin's on the side frames that bolt to tractor, you just undo the pin's and they come right out and then you take the bolt's off with the mount's at the tractor frame, I think you have to jack the back up, and then undo the hydralic pump from the PTO shaft in back, And you have to undo the mounts at the axle's on tractor, THEN,,,,, AND ONLY THEN WILL THE TRACTOR COME OUT THE FRONT! I mean If you can get the head, and pump off the front and back, then I guess the rest of it will come off, and then I can see If someone wants it, Or just give it to someone that need's one that work's right, I mean thier kinda neat,,, But I dont have any use for one steve, I dont have alfalfa, or hay, or horses, A friend of mine want's to use it to take an old TV tower down on the side of his house, so Ill let him use it first, and then take it apart, and get it off there, And dive into tractor, Keep In Touch ok, Ill Talk to ya Later ok, Kirk,
