Wood Bearings
Gary Hayes
03-29-2008 10:59:24
I found a company that still makes wooden bearings http://www.pobcoplastics.com/pg_50.htm
I am restoring an old dearborn disc that has wooden box bearings..... .
Billy NY
03-31-2008 09:30:36
 Re: Wood Bearings in reply to Gary Hayes, 03-29-2008 10:59:24
I was wondering if anyone made these, be it a manufacturer or just a local woodshop, that could turn and bore out a hardwood bearing, that you could soak with oil, I have an old unidentified 3 pt disc, that came from our ford dealership, never did figure out who made it, it has cylinder shaped wood bearings on the gangs, some have worn a bit.
Sagebrusher
03-30-2008 06:54:13
Hi Gary,
Thanks for the info. Please let us know what approx sizes your bearings are and how much Pobco wants for them. I am toying with rebuilding an old JD that needs a few wooden bearings and discs. Had thought that maybe this summer I"d try turning some on the wood lathe and then boring them with a Forstner bit. Cheers Don
`Bernie in MA
03-29-2008 14:16:01
I still use my Dearborn disc with the wooden bearings but not as much since I sold my cows 36 years ago. I bought it new in 1956. Back in the late 60s I couldn't find the wooden ones so I converted one gang to JD cast iron. Probably can't get those now either. Thanks for the info.
msb
03-30-2008 19:02:52
 Re: Wood Bearings in reply to `Bernie in MA, 03-29-2008 14:16:01
Those would most likely be white iron, Bernie.
