Seed Plates ?
Bill Lewis
03-29-2008 05:51:46
I have a 494-A 4 row John Deere Planter.Can anyone tell me what seed plate to use with the corn seeds I listed below?
Truckers Favorite White O.P. Corn
Truckers Favorite Yellow O.P. Corn
Iochief Hybrid Sweet Corn
johns48jdb
03-29-2008 17:56:26
 Re: Seed Plates ? in reply to Bill Lewis, 03-29-2008 05:51:46
years ago jd was so concerned about this problem that they made a motorized planter demo model that you could put your seed on and turn it on and see what happened. they would first size the seed you have to the size of plate that they thought you should use. does any body remember seeing this info in either two cylinder or green magazine?
ejr-IA
03-29-2008 15:31:35
Here are some numbers of plates I found in a older planter book.Size of corn Med 780b,1239b,large 963b,small 964b,extra small 1240b these plates need the y2630b false ring or h1346b floor plate. The plates are 16 cell.
larryh
03-29-2008 14:17:19
we sell seed and could try and match the seed to our plates but your seed could be a different size do you have any plates to try if so lay grain on side and try and put in seed slot on plate if you need a bigger or smaller plate we can help you if we know what size you try and get me the plate no.
Bill Lewis
03-29-2008 17:59:20
 Re: Seed Plates ? in reply to larryh, 03-29-2008 14:17:19
I HAVE SEVERAL DIFFERENT SEED PLATE FOR ROUND AND FLAT. I WILL TRY WHAT YOU SUGGESTED TO PICK THE ONE THAT WORKS BEST, THANKS.
jjamna
03-29-2008 10:19:37
I take about a quart or so of seed and put it in the hopper and turn the planter by hand. Use different plates till I find the one that works the best. U can narrow it down by are the seeds flat or round. And if they look big or small.
Bill Lewis
03-29-2008 18:03:37
 Re: Seed Plates ? in reply to jjamna, 03-29-2008 10:19:37
I HAVE SEVERAL SETS OF SEED PLATES FOR ROUND AND FLAT. I WILL SET THE PLANTER UP AND DO WHAT YOU SUGGESTED TO SELECT THE BEST SEED PLATE FOR THE DIFFERENT CORN SEEDS , THANKS VERY MUCH, THIS WILL WORK.
IaGary
03-29-2008 09:43:58
Need to know the seed size. MF,LF,SF,LR,MR,SR and so on.
If it is not on the tag you may have got a plateless grade which will be a problem with a plate planter.
Bill Lewis
03-29-2008 18:11:04
 Re: Seed Plates ? in reply to IaGary, 03-29-2008 09:43:58
Ok , I get the idea, Since I already have the seeds I will have to take different seed plates to find the one that works the best with each verity of seeds I have. I am going to jack up my planter to test run a number of different plates to just see which one works the best. I have several sets of plates for round and flat corn seed, thanks again.
Bill Lewis
03-29-2008 09:55:38
I DON,T KNOW THE SEED SIZE,BUT THEY ARE GRADED SEEDS.I WAS LOOKING FOR SOMEONE THAT HAS PLANTED THIS TYPE OF CORN IN THE PAST THAT WOULD KNOW THE SEED PLATE NUMBER THAT WAS USED, THANKS ANY WAY.
IaGary
03-29-2008 10:37:32
 Re: Seed Plates ? in reply to Bill Lewis, 03-29-2008 09:55:38
That type of corn can come in various seed sizes.
As can all varities of corn.
I order the variety I want in the seed size I want.
Gary
Bret4207
03-29-2008 06:24:03
Usually the plate size is on the seed bag.
Bill Lewis
03-29-2008 08:46:37
 Re: Seed Plates ? in reply to Bret4207, 03-29-2008 06:24:03
Problem is I already have the seeds and there was not any information about seed plates on the bag.
