HELP ....expensive mistake.
nates90
03-25-2008 18:36:47
Well, I bought some Yetter No-Till coulters for my IH 800 planter and I found out that IH made two different cast iron row unit brackets, and mine are the wrong ones. I was wondering if they made some sort of an adaptor kit so these would work. My cast iron piece only has one mounting hole and these Yetters require two holes. Please help me out, I bought these Yetter units slitely used, so I cant take them back. I am guessing the other cast iron piece for the planter would cost around 150-200 a row. Thank you for any information.
IaGary
03-26-2008 04:28:10
 Re: HELP ....expensive mistake. in reply to nates90, 03-25-2008 18:36:47
Can you drill the other hole and make them work?
Gary
nates90
03-26-2008 05:32:53
 Re: HELP ....expensive mistake. in reply to IaGary, 03-26-2008 04:28:10
If you look at the yetter site that wdct630 sent, you can look at the mounting bracket on the planter and I"m missing the top hole. I think i might figured something out, I will have to cut and weld a 1/2" I.D. pipe to some of the stamped steel on the planter, I just hope it will be strong enough, might have to weld some gussets with it. It just upsets me that Yetter doesnt cover both kinds of cast iron parts on the planter.
wdct630
03-25-2008 18:50:50
have a few yetter products found there site very helpful have all the manuals there.
