danuser wood splitter
jerry s
03-24-2008 17:57:30
i need help on a danuser wood splitter the cyleder went out and would not go back in i think it is the return valve i possible spring any insight would be apperciated
jerry s
jerrys
03-25-2008 17:33:43
 Re: danuser wood splitter in reply to jerry s, 03-24-2008 17:57:30
i am going to try it in the morning to see if i have it i am thinking it may be the valve
El Toro
03-24-2008 18:10:48
You should check to see if there's fluid from that hose that retracts the piston when your control valve is put in the retract position. Place the hose in a clean container & hold it with one hand so it doesn't spray on you. Just do
it for a few seconds and release the control handle. If there's no fluid your control valve is probably defective. Hal
