IH 440 baler
GI FARMER
03-24-2008 10:40:16
I am trying to change the rollers (wire guide) at the end of the needles. Does anyone know the best way to get them out? Is it a rivet that holds them in? Should I drill it out? Should I take the needles off to do this? I bought this old baler last year and after getting some of the kinks worked out it seems to work fine so I thought I would keep it around a few more years but I wanted to fix it up some. any and all advice is welcomed Thanks
Mark
ArleninOr
03-25-2008 18:30:52
 Re: IH 440 baler in reply to GI FARMER, 03-24-2008 10:40:16
Can maybe copy the pages that show this as it looks as if you can use a screw with nuts.
ArleninOr
03-24-2008 17:56:36
According to my book there is a rivet to be drilled out. If you need part numbers let me know.
GI FARMER
03-25-2008 07:15:16
 Re: IH 440 baler in reply to ArleninOr, 03-24-2008 17:56:36
Thanks the part # would be great all I have is an operaters manual
haysaver
03-25-2008 10:38:08
 Re: IH 440 baler in reply to GI FARMER, 03-25-2008 07:15:16
My book shows two rollers on each needle.
one on the end is the #667 413 R1
has a bushing # 667 414 R1
second one is # 667 412 R1
has bushing # 667 415 R1
also lists rivit # 102 688 (3/16 x 13/16) rivit # 102 689 (1/4 x 13/16)
my book does not show which rivit goes where.
GI FARMER
03-26-2008 05:47:29
 Re: IH 440 baler in reply to haysaver, 03-25-2008 10:38:08
Thanks I knew sombody out there could help, now if I could just talk you into comeing over to the shop and helping me change those out that would be great. ha ha ,but seriously thanks.
johns48jdb
03-24-2008 16:06:32
glad you got a 440 that was a good one. mine was a dud from day one. the inside twine was so close to the edge of the bale you had to be very careful handling them. on the eyes i wouldn't remove the needles under any circumstance. your opening up a hold new box of bees if you do. it will take forever to get them right. if you tighten them up any at all only pull each bolt a 1/4 turn or less and then the other one. undo the needles from the drive and move them by hand up where you can get to the easier. you can remove the bolt that holds the knotters in place and swing them up if you need more room. notice where and if any washers are at between the frame and knotters. while they are up there you can measure the location of each needle before you snug the bolts up the holds them on to the u shaped swing bar, if they need tighting at all.
