M 12 volt
Lee in Iowa
03-23-2008 23:20:30
My M that has been converted to 12 volt needs a new coil can I use a 12 volt coil and eliminate the ballast resistor or should I stick with the 6 volt coil and the resistor. I've got a good 12 volt on hand and would like to use it. Thanks Lee
El Toro
03-24-2008 03:38:52
 Re: M 12 volt in reply to Lee in Iowa, 03-23-2008 23:20:30
You can buy a coil from NAPA that has a builtin ballast resistor for about $18.00. p/n IC14SB
This will prolong the life of your points. Hal
