AC Bar Rake Questions
rwskinner
03-22-2008 07:05:56
I have a small 10 ac. hay pasture (Coastal Burmuda) that I round bale once per year. Neighbor has a 10 acre pasture of Tifton he wants me to start doing.
I've collected and rebuilt the following. NH851 Round Baler, 459 Moco. and I have been looking for a hay rake but they are hard to find around here.
I ran across an old AC Hay rake, axle driven belt drive. Pretty sure it was a 4 bar. Besides needing tires, it's all operational. Guy wants $400 for it. Doesn't look like much could go wrong with it really, all cast iron, steel, and a few bearings.
Questions:
1) Is $400 a fair price or too much?
2) Will this old bar rake work for what I need, at least get me by until I find a good used wheel rake?
3) Any idea what model this may be? Model 77 or 78
Thanks,
Richard
DiyDave
03-23-2008 11:03:52
 Re: AC Bar Rake Questions in reply to rwskinner, 03-22-2008 07:05:56
If you go over to the left side of the page here, and search implement photos, you will find a picture of a shiney, fresh painted A/C # 78 rake. I think the difference between the rakes is the rear axle. The one on the diagonal is preferred, as it turns better. $400 is an excellent price, as long as everything works.
rwskinner
03-23-2008 20:48:23
 Re: AC Bar Rake Questions in reply to DiyDave, 03-23-2008 11:03:52
Dave, Good looking Rake. I replied earlier but it never posted. The Rake I'm looking at is almost identical except for two things.
1) This one has a solid axle and a belt drive.
2) The Spindles/Pullys offset to the right so bars move from left to right.
Richard
RayP(MI)
03-22-2008 08:35:59
Can"t help ypu on price, depends a lot on what you need to add/fix to make it workable. My rake used smaller tires, and we ended up buying utility trailer tires. Just note that there was a lot of hay raked with conventional bar rakes before the wheel rakes came into play. Lots of bar rakes still in use, including mine. I really prefer over wheels, as I think they do a cleaner job.
BCnT
03-22-2008 08:35:17
i'm using a old Ford ground driven rake to feed my 851...its 5 bar but 4 should work ok too...you aint gonna set any speed records but will get the job done.
if rakes in that good a shape its prob worth it...prices been all over at auctions...i'd say its worth a little more if you can actually talk to owner before you buy.
